Transmission Grinding
I just swapped a 5sp into my EA81 I have the clutch adjusted correctly I believe, but it still grinds going into 2nd gear and it has begun doing it going into 4th as well.  It is worse down shifting than up shifting.  I have also tried double clutching to no avail.  Ideas?  I am running the EA81 flywheel and pressure plate with the EA82 clutch.  Could this be it?
I drove the parts car it came out of home.  I don't remember any grinding or anything to that effect.  The only thing I remeber being an issue was the clutch being shot and having to nurse it home.  Can you elaborate on the uninstalling the shifter and said machanisms?  I am not really sure what you mean by that.  When I did the tranny swap, I only changed the 4wd linkage.  I never even detached the regular linkage.
