EA82T Turbo manifold
90% of the time in my case the exhaust manifold leak has been due to failed gaskets on the heads. Once I had a cracked echaust pipe right under the turbo flange too. There is four mounting screws for exhaust manifold per head but factory uses only two of them so It is advisable to mod the heads to use all four of them if there is any bad bolts in there. If possible it's a good dea to manufacture a whole new exhaust without that nasty original T-joint in it too.
EJ manifolds don't fit directly.
