* * * * * 1 votes
Subaru noob coolant hose question
26 replies to this topic
#26 heartless
heartless
    Do YOU Subaru?
  • 3,296 posts
  • North Central Wisconsin
Posted 30 July 2013 - 09:38 AM
yes, filling the block from the upper rad hose before connecting it is the recommended procedure.
also, use the bleeder on the passenger side top corner of the radiator to facilitate burping - small white plastic fitting with philips type slots - removing it while filling will get/let the air out faster & more completely.
#27 vladvv
vladvv
    Advanced Member
  • PipPipPip
  • 38 posts
  • Binghamton, NY
Posted 30 July 2013 - 10:07 AM
Excellent info, thanks! Did you end up doing the heater hoses?
I usually park on a slight uphill, fill the radiator, then fill the block using the upper rad hose (full as possible before connecting it) and haven't had a problem.
Yes I didn't take pictures but I replaced the throttle body hose, the water pump hose, both heater hoses and the rad hoses. The Gates hoses worked really well.
I neglected to fill from the top hose, I figured filling radiator would go down that hose anyways. Also the small plastic fitting I removed and when I was replacing it I snapped it off, but it did seal so I'm just going to leave that alone until I grab one from the junk yard or something.
Edited by vladvv, 30 July 2013 - 10:07 AM.
