06 Outback radio question..
6 replies to this topic
#1 subie94
subie94
    Major Subaru Fan..
  • 1,583 posts
  • Epsom,N.H.
Posted 21 July 2013 - 04:33 PM
Is it even possible to replace with aftermarket radio ? considering the surrounding panel is also used for HVAC controls..I just wish i could listen to all the music that's on my MP3 in my new Scoob..
If not,guess i'll have to burn a few CDs then..  :huh:
#2 Cougar
Cougar
    Elite Master of the Subaru
  • 6,563 posts
  • Anchorage
Posted 21 July 2013 - 05:27 PM
Why don't you use a FM transmitter for your MP3 player to work with the radio?
#3 ShawnW
ShawnW
    Subaru Master Technician
  • Administrator
  • 12,955 posts
  • Denver, Colorado
Posted 21 July 2013 - 06:56 PM
I found the kit on Crutchfield before.  I haven't used it yet but I have seen a few that had it done and it turned out ok.
#4 mikaleda
mikaleda
    legacy specialtist
  • 2,263 posts
  • priest lake, Idaho
Posted 21 July 2013 - 08:51 PM
nipper has a thread on this subject, there is a mod that will give you room to put a radio in without trashing your hvac controls.
it does involve cutting the circuit board and doing some fine soldering
#5 subie94
subie94
    Major Subaru Fan..
  • 1,583 posts
  • Epsom,N.H.
Posted 22 July 2013 - 04:55 PM
For now i just burnt a few CDs but will probably go the FM transmitter route..wanna keep Silvia as stock as possible anyway..Thanks though.
#6 nickb21
nickb21
    Subaru Fanatic!
  • 567 posts
  • Hunterdon County
Posted 22 July 2013 - 06:18 PM
I have seen replacement surrounds that let you mount DIN radios, they look fine.
If you go FM transmitter, consider using an in-line type. More time to install but better sound quality.
You could also look for someone selling a newer OE radio, they added an aux in maybe in 07?
Lastly, I thought someone had made an adapter that would plug into the SAT or changer input or something to give you an AUX in without hacking wires/etc..
Edited by nickb21, 22 July 2013 - 06:19 PM.
#7 nickb21
nickb21
    Subaru Fanatic!
  • 567 posts
  • Hunterdon County
Posted 22 July 2013 - 06:29 PM
Ah:  http://ae64.com/Lega..._Transplant.htm
Well that's annoying that you can't "easily" add an AUX to 05-06 cars. Hope the info helps, good luck!
