Phantom LSD
10 replies to this topic
#1 Mugs
Mugs
    Subaru Fanatic!
  • 546 posts
  • Spokane & Hobart, Wa.
Posted 28 July 2013 - 07:12 PM
Anyone have experience with this type of LSD. I am thinking about putting it in my 2000 Outback Sport auto..4.11 rear diff. I think the Forester has the same ratio. Seems like a good option as sourcing a LSD is getting pretty hard these days.
Or will it even work?
#2 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 29 July 2013 - 03:41 AM
It works about the same as putting extra washers or grinding disks behind the spiders to "lock" the diff.It marginal at best until the metal slurry it creates locks the diff up for real.
Edited by Uberoo, 29 July 2013 - 03:41 AM.
#3 monstaru
monstaru
    wow, relevance....
  • 4,453 posts
  • OlyWa
Posted 29 July 2013 - 08:07 AM
Not worth it Doug.
They do not have a good track record.
Just get a VLSD. They work really well for what they are.
cheers
#4 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,375 posts
  • Seattle
Posted 29 July 2013 - 11:00 AM
I've got one cheap enough, contact me.
#5 Mugs
Mugs
    Subaru Fanatic!
  • 546 posts
Posted 29 July 2013 - 11:45 AM
I tried that.....it says you can not receive any new messages  :angry:
#6 ezapar
ezapar
    [OTD]
  • Moderator
  • 27,375 posts
  • Seattle
Posted 29 July 2013 - 11:54 AM
Cleared room in my inbox, sent you a pm.
#7 Mugs
Mugs
    Subaru Fanatic!
  • 546 posts
Posted 29 July 2013 - 12:04 PM
Thanks for all the input guys. Its much appreciated.
One of these days I might fork over the big bucks and buy a LSD center diff. But that won't be for a while. I want to do the 2.5 swap and get this guy off the ground a bit more first.
#8 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 29 July 2013 - 09:45 PM
The vlsd rears are pretty common in the junkyards now. Lots of the 2nd gen Legacy Outbacks came with them. 4.11's in the 5spd's, 4.44's in the a/t's. Look for heated mirrors, if it has them it has the winter package which came with the vlsd.
If you want to spend big bucks, a 4.44 front ring and pinion plus an obx helical front diff with a vlsd 4.44 out of an auto trans outback would be a pretty good setup. Most of your traction is on the front wheels, so that's where the lsd makes the biggest difference.
#9 Mugs
Mugs
    Subaru Fanatic!
  • 546 posts
Posted 29 July 2013 - 11:04 PM
Yah eventually I might bump up to the obx heli vlsd..there about 6-800 bones on the inter-web. Gonna do a few other mods to it first.
I'm pretty sure I have the 4.11 diff..Its a 2000 Outback Sport (Impreza) with the 4EAT and the EJ22, which to the best of my knowledge and reading is the 4.11..the EJ25 OBW (and other cars) came with 4.44...then again I could be heinously wrong.
I guess it is time to go count drive line revolutions per 5 tire turns.
Edited by Mugs, 29 July 2013 - 11:06 PM.
#10 WoodsWagon
WoodsWagon
    Formerly 91Loyale
  • 4,102 posts
  • NH
Posted 30 July 2013 - 02:01 PM
A diff from the junkyard shouldn't be more than $150 and a stock late model vlsd will work a lot better than the phantom grip. The phantom grips are bad  news, they work by wedging the side gears into the case until the oil squishes out and it's grinding metal  on metal. That's the limited slip action.
#11 Mugs
Mugs
    Subaru Fanatic!
  • 546 posts
Posted 31 July 2013 - 12:30 AM
Ya I got a Vlsd from a forum member here. Its out of a 2000 RS. Should be here by the end of the week.
I'm super stocked about it.
