With the hot months coming and having arrived on certain days, I've realised that my AC doesn't work. I had the system refilled last fall (so I doubt it needs refrigerant) so it hasn't been warm enough to check if it works properly. Anyway, there is no cool air coming from the vents, even after 5 minutes of operation. I've also noticed that when I turn the AC on, there is no engine rpm change, is this normal? Shouldn't the engine experience a short fall in rpm due to the extra load?
Any suggestions where I should start to look?
Thanks.
