Turbo Exhaust for 93 4wd Loyale.
5 replies to this topic
#1 lascoflats
lascoflats
    Member
  • PipPip
  • 12 posts
  • Durango, CO
Posted 01 August 2013 - 01:22 AM
Hello,
I am new to this site.  I have a 93 4WD Subaru Loyale.  Needs a new exhaust.  Multiple holes. Anyways I am slowly working on it to be a sleeper.  I want a exhaust with a turbo muffler.  Just looking for suggestions, anything helps.  Thanks.
#2 lascoflats
lascoflats
    Member
  • PipPip
  • 12 posts
  • Durango, CO
Posted 03 August 2013 - 10:44 AM
Recently found out that the original owner swapped out the motor for a 1986 motor.  Found a hand written wiring diagram and probably did so for the MPFI and Turbo.  Thanks.
#3 scoobiedubie
scoobiedubie
    USMB is life!
  • 691 posts
  • Aloha, Oregon
Posted 03 August 2013 - 11:03 AM
An aftermarket muffler can be bought anywhere.  There is nothing special about Subaru mufflers, other than power loss from the small diameter exhaust system.  A 2 1/2" diameter system coming off of the first cathodic downpipe, that eliminates the 2nd cathodic gismo, will give you better power.
#4 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 03 August 2013 - 11:23 AM
So, are you saying that your 93 has an MPFI/Turbo motor in it?
#5 lascoflats
lascoflats
    Member
  • PipPip
  • 12 posts
  • Durango, CO
Posted 05 August 2013 - 12:59 AM
Yeah I know that Subaru's are not special pertaining to their mufflers.  I am just curious of exhaust suggestions.
That's exactly what I am saying.  I did not know this when I bought it.  I bought it from the second owner.
#6 BoxerRebellion
BoxerRebellion
    Advanced Member
  • PipPipPip
  • 114 posts
  • Portland, OR
Posted 05 August 2013 - 10:41 AM
The cheapest route would be to locate the same exhaust in an acceptable condition at a U-Pull-It.
The non-cheapest route would be to purchase pipe at the desired diameter and have it bent.
-That is, unless you've a buddy with a bender that'll work for six-packs ; )
(Pipe is cheap, bending is not)
In terms of a muffler, you'll most likely be happy with anything if it's from a good, trusted brand.
Characteristics to consider - Price, Size, Throaty or not, loud?
Perhaps consult a local Subie shop - I'm sure there's some in Colorado - ask them to chime in.
Good contacts can often be met with little work.
