how about adjusting/replacing the lifters? wondering if i would need to pull the engine or if i could do it without that. mine sits 2 inches lower as i did put a lift on it.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
lifters
#1
Posted 05 August 2013 - 01:57 AM
#2
Posted 05 August 2013 - 02:07 AM
If you have the 88 GL (had to look at your profile) then you should have an EA82
I did my lifters with the engine still in the car... need to pull the valve covers off (might as well replace the seals and grommets while youre in there), remove the cam tower (and get some RTV to reseal those when you put it back together... pull the rocker arms (pretty important to keep these marked on cardboard as to where they went... lifters sometimes just pop out but might need slight help but they should pop out none-the-less, just be gentle... Then send them in to be rebuild... IIRC Mizpah is like $5 a lifter or $8 if you wanna just buy theirs.
Edit: $4.50 if they rebuild yours, $6 to buy theirs -- Link -- http://mizpahprecision.com/pricing.htm
When installing, use some assembly lube to hold the rocker arms to the lifters (you don't want them to fall) Then use Ultra Grey RTV (or equivalent sealant) and put it on the cam carrier, use torque specs of course, youll want to go to a dealer for the cam-tower O-rings, and while its off, clean the cam-tower of the oil residue and use a small toothpick (or equivalent) to clean the oil passages and reassemble... Using new seals and grommets would be wise.
Since you have oil pressure issues with the TOD, Id also recommend replacing your oil pump or at least the mickey mouse seal and O-rings.
#3
Posted 05 August 2013 - 06:13 AM
what symptoms do you have that require it? they generally last the life of the car unless they have like 200,000+ miles and/or have been abused.
if they're simply ticking then the most likely culprit or solution is the oil pump:
1. reseal the oil pump
2. replace the oil pump with a new one
*sometime if you're short on time and don't want to do the job twice it's simplest to just jump to #2
for more info: http://www.ultimates...ose-and-repair/
if you still want to play with them you can:
1. rebuild them youself - disassemble, clean, reassemble. the top retainers are old, brittle, and prone to crack when prying/removing so tread carefully. i've done it but consider it a waste of time when you can do this:
2. buy them for like $5 http://www.mizpahpre...com/pricing.htm
#4
Posted 25 August 2013 - 11:17 PM
#5
Posted 26 August 2013 - 12:13 AM
+1 i love mizpah, very good work
#6
Posted 26 August 2013 - 09:29 AM
What exactly does Mizpah do to refurbish the lifters?
#7
Posted 26 August 2013 - 09:38 AM
change brown seal in oil pump and orings
#8
Posted 26 August 2013 - 05:16 PM
Next month I will be doing head gaskets. I will be so far into the engine that replacing the lifters would be easy. But they are not ticking. Should I just go ahead and do it as preventative maintenance? Not worried about the cost so much as Murphy's Law of fixing something that ain't broken. Of course after 20 years and 150K miles, it might be best.
#9
Posted 26 August 2013 - 11:13 PM
#10
Posted 27 August 2013 - 08:40 AM
ea82 lifters good for 300000kms no porblems oil pump seals change every 100000kms or when it starts ticking
#11
Posted 27 August 2013 - 09:09 AM
they're only like $3 - $7 each from Mizpah so if you're not worried about cost then that's your call.
as said - they're good for the life of the car if you change oil properly and when you have issues:
once you reseal the engine you'll have new cam carrier orings too, make sure you get the metal reinforced variety for the two lower corner orings. they are not regular orings as is installed in some early 85/86 EA82's.
if the car has a long unknown history or questions maybe it's a good replacement time.
if you've put a ton of well maintained and quiet miles on it then they're unlikely to have issues.
totally doable but i dislike replacing the HLAs, cleaning up the cam carriers and reinstalling them with the rocker arms, i hate that job. so i can see erring towards doing it now while it's apart too!
Edited by grossgary, 27 August 2013 - 09:10 AM.
#12
Posted 27 August 2013 - 09:20 AM
I built a tool to compress the spring in position so can slip follower out and change lifter without teardown sitting in my tool box unused for 6 years now
#13
Posted 27 August 2013 - 10:11 PM
No unknown history with this engine. Every single one of the 150K miles is mine. I have owned the car since new. Dealer did first timing belt at 60K, then I did the next at 117K and then I also did cam seals, new water pump, new Subaru oil pump, clutch, rear main seal and of course idlers for timing belt. Folks said I should have done the HG at the time(2008 I think) but it was my first timing belt and I was unsure of myself. I pulled the engine and had my mechanic for life father hovering over me lecturing me on how I was going to wreck the engine when I took off the timing belt. He'd never seen a Subaru and didn't quite get when I told him it was a non-interference engine. Showed him though when it started up the first time.
#14
Posted 27 August 2013 - 10:13 PM
pic of this tool?
3 followers fell out of my XT6 after a headgasket job
Edited by grossgary, 28 August 2013 - 01:49 PM.
