cv castle nut loosening
12 replies to this topic
#1 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 21 April 2004 - 05:38 PM
im guessing if my castle nut was loose yesterday, and i tightened it, and today again, its a bit loose, it must be my bearings are shot, and grinding themselves to powder, right?
#2 subiemech85
subiemech85
    SIX STAR SERVICE
  • 2,710 posts
  • down by the river
Posted 21 April 2004 - 05:50 PM
you never said anything about the big cotter pin that keeps the nut in place
#3 GeneralDisorder
GeneralDisorder
    Elite Master of the Subaru
  • 21,300 posts
  • Portland
Posted 21 April 2004 - 07:31 PM
Front or rear?
#4 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 21 April 2004 - 08:08 PM
Castle nut loosening has nothing to do with the bearings being bad. This happens for one of two reasons: Either there was dirt or goop on the inside of the wheel hub where the axle enters the hub that has worked its way out hence loosening the nut. The other possibility is that the beveled washer wasn't tight and finally seated itself which results in loosening the nut. Thirdly, it might not have been tight enough to start with--145 ft-lbs is a lot, but you can tighten it even more if you like without damage. Oddly enough when it loosens like this, it even sounds like the bearings have gone bad on that side.
#5 GLCraig
GLCraig
    Frak
  • 2,706 posts
  • Canby @#$% Oregon
Posted 21 April 2004 - 09:25 PM
There is another reason that this happens. Sometimes the splines in the hub will wear out and cause enough vibration to loosen the nut. If this is your case you should inspect the splines on the axle for damage too.
#6 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 22 April 2004 - 08:23 AM
well thats the thing, the cotter pin in in, and i tightened it about a month ago, when i did the cv. today will be the third time i have put a big cresent wrench on there, and stood on it, to get it tight. last time i tried a different conical washer, and flat washer, and it started again. its not like the nut is loosening, the metal behind the nut is shrinking, or the axle is continually getting pulled closer to the nut.
#7 calebz
calebz
    Andys Coupe killed my cat
  • Administrator
  • 7,547 posts
  • Tacoma
Posted 22 April 2004 - 08:49 AM
Sounds like the axle wasn't all the way in, or, like edrach said, there was gunk behind it that is getting squished out... also, not sure about the wisdom of the large cresent wrench.. may want to consider investing in a 36 mm socket
#8 edrach
edrach
    RIP 6/28/14
  • 12,326 posts
  • Bothell, WA
Posted 22 April 2004 - 10:24 AM
I'm with caleb on the cresent wrench. I suspect you're not getting enough torque on the nut with a cresent, even if you're standing on it. A 36mm socket with a breaker bar (and maybe a 2 foot extension with a pipe) is a good bet.
#9 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 22 April 2004 - 03:39 PM
took it apart, and the bearings were eating themselves, lotsa metal shavings. crescent wrenches work fine, on nuts that big.
$22 fix
#10 HillbillyLes
HillbillyLes
    User Awaiting Email Confirmation
  • 272 posts
  • North Central Missouri
Posted 22 April 2004 - 05:02 PM
'Crescents are o.k. on nuts that big' (and to torque 145 lb.ft.).........
and they call ME "Hillbilly".:brow:
You're right, they will work...in a pinch, but sometimes a little investment in the proper tool goes a long way. Suit yourself...
Just an observation.
HbL
#11 baccaruda
baccaruda
    YOUR FAVORITE MOD
  • Moderator
  • 6,950 posts
  • SpoVegas, WA
Posted 22 April 2004 - 06:03 PM
also, the washer that goes between the beveled washer and the castle nut is curved like so: (
you want the convex side facing out. some are marked OUT on the washer itself. the curvature is easy not to notice.
#12 archemitis
archemitis
    guy smiley
  • 3,554 posts
  • the big minnie
Posted 22 April 2004 - 06:08 PM
if the cresent doesnt slip, and i stand on it, and i am applying pressure 1 foot out, i weigh 145 lbs. see where im goin with this?
i didnt fix it yet, but my bearings are shot, and thats gotta be the reason, its getting looser and looser. the center spacer and bearings are getting smaller and smaller.
#13 MorganM
MorganM
    Do you Subaru?
  • 8,390 posts
  • TwinCities
Posted 23 April 2004 - 09:55 AM
I was gonna say you could use my 36mm and braker bar but you were already standing on your cresent wrench when I came outside lol
Glad to hear you found the culprit. Maybe we can do the bearings and rear disc conversion all at the same time? I've never had to do wheel bearings on these so I could use the xperience :)
