luvmysubi Posted August 9, 2013 Share Posted August 9, 2013 My Brother called me and said he broke down on hwy 79 near DeBerry and having it towed. Fuel pump not working, having it towed to Motel in Carthage Tx. Anyone near by that has a used one? He knows how to take it out if he has enough tools with him. He doesn't have a test light with him. So he is limited. Anyone hear by or know someone that might give him a hand. I have parts for it but am to far away. he is trying to get back to TN. It is a 97 OB wagon If you can help. he can be reached at 865-356-4952 Thank you and I will make it up to whom ever helps Quote Link to comment Share on other sites More sharing options...
john in KY Posted August 9, 2013 Share Posted August 9, 2013 Just replaced my pump 2 months ago. Thinking a philips screwdriver and a 10mm socket with an extension to get down in the well is all that is needed. Hardest part is removing the 3 hoses. Also recommend a OEM Subaru pump. The pump I used from an online store stated the pump was "a direct replacement". It wasn't and required cutting and splicing wires and it was much smaller than the stock pump. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted August 9, 2013 Share Posted August 9, 2013 www.car-parts.com search by zipcode - he'll get the closest yards that have a subaru. subaru says 1995 - 1997 are the same fuel pump but i bet there's a much wider range of pumps that interchange. if you need to start a thread titled "what fuel pumps interchange with 98 OBW" in generally he could wire up any pump to limp home. use those wire taps - that bite into the wire rather than splicing/cutting. Quote Link to comment Share on other sites More sharing options...
