86 Turbo XT 4wd re-assembly, stuck help!
11 replies to this topic
#1 Mr. Carb
Mr. Carb
    Weather Geek
  • 903 posts
  • Everett, WA
Posted 12 August 2013 - 04:27 PM
I tried searching and it was about as useful as a paper weight.  I was wondering if anyone that knows or has an ea82 turbo engine could tell me more about where the wires coming off of the distributor plug into?  I have 2 wires that go to the coil, and a third single wire that I can't figure out where it goes, it's short, only reaches as far as the two wires that go to the distributor reach.   Any ideas?
Also the battery wires going to the starter motor have a metal bracket attached to them, I can't figure out where that bracket is supposed to attach either.
These are my only two mysteries so far putting this car back together.
Thank you for any help!
Edited by Mr. Carb, 12 August 2013 - 04:27 PM.
#2 john in KY
john in KY
    1000+ Super USER!
  • 1,681 posts
  • KY
Posted 12 August 2013 - 04:49 PM
Thinking the transistor attached to the coil bracket has a small wiring harness.
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 12 August 2013 - 05:18 PM
What year? 85 and 86 mpfi have a mechanical disty and an external knock control unit. The balck wire is positive and the yellow wire is negative. The other odd plug may be for the knock sensor on top of the block near the timing plug. The knock control unit is installed in the passenger ide fender behind the strut tower.
the metal bracket on the ground starter cable goes on after the starter is aligned to the std, and before you put the bolt through. It installs on the rearward face of the starter 'ear'
The bracket fits to there the bolt part fotr the cable itself overlaps forward on the starter ear.
Edited by MilesFox, 12 August 2013 - 05:19 PM.
#4 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 13 August 2013 - 01:55 PM
Is it a single wire with a hook/eyelit on the end? like the other two that go onto the small terminals on the coil?
If so, could be for the RPM signal to the cruise control unit.. (At least that's what mine was)
#5 Mr. Carb
Mr. Carb
    Weather Geek
  • 903 posts
  • Everett, WA
Posted 15 August 2013 - 03:57 PM
Thank you for your help, I have to figure out how to get the usmb to notify me people have replied. lol.
Bracket instructions make sense and help a lot, i'll get that installed, starter was already in, so that makes since why I didn't see where it goes. :lol:
Knock sensor is already plugged in.  This wire is at the other end (drivers side) by the coil, it's a spade plastic clip (normal subaru electrical plugs) type connector (black and yellow stripe if I remember right) separate from the two coil wires but it comes out of the same spot of the harness, and is about the same length of wire as the coil wires.  The other harness I pulled out has the same wires (identical).  I replaced it because the knock sensor plug on the old harness was busted.
#6 Mr. Carb
Mr. Carb
    Weather Geek
  • 903 posts
  • Everett, WA
Posted 15 August 2013 - 03:59 PM
It's a 1986, sorry forgot to add that.
#7 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 15 August 2013 - 08:17 PM
Whoops, i missed that part when i posted although it says so in the thread title!
The single wire you mention with the plastic molded clip fits on the spade on the back of the starter solenoid.
#8 Mr. Carb
Mr. Carb
    Weather Geek
  • 903 posts
  • Everett, WA
Posted 16 August 2013 - 08:58 PM
Nope, different wire, that one is already hooked up.
This wire is about 4 inches long and it comes out of the same group of wires next to the distributor as the 2 wires that hook up to the ign coil (from the engine side)
Edited by Mr. Carb, 16 August 2013 - 08:59 PM.
#9 Gloyale
Gloyale
    It's a sickness
  • 10,923 posts
  • Corvallis, OR PNW
Posted 17 August 2013 - 04:28 PM
I believe that wire originally spaded into another little stretch of black wire with a Eye on it that bolts down to the water pump tube holddown.
#10 jono
jono
    Reader and writer
  • 1,859 posts
  • Southern Hemisphere - AUS
Posted 17 August 2013 - 07:01 PM
The 85/86 EA82T sedans nonXT had a white plastic plug with black wire, yellow? stripe/trace that is a test plug - remains disconnected. At ignition on only will have 5.0 Volts, engine running 1.7V until a knock to block with detonation or simulated with a hammer - can jump to 4.5V
This it ?
#11 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
Posted 17 August 2013 - 08:52 PM
I just worked on an 86 xt today. Although it has some horribly cobbled together engine/intake/intercooler. I noticed it has the same wire, and of course, it is not connected to anything. There are other wires not going anywere, which i would guess go to the ac system which has been deleted.
But there are so many odd plugs that don't go to anything. But then again part of the trans harness is missing, it is an 86 body with an 87.5 spider intake and a ford intercooler.
 But hthe car runs although it is not tuned properly at all and is basically un-tuneable
#12 leniac
leniac
    New User
  • PipPipPip
  • 71 posts
  • Chile
Posted 19 August 2013 - 08:32 AM
pics... we need pics of the engine to compare....
