91 Loyale; noisy brake drums
It is due to a combination of brake dust in the drums as well as the drum and shoes being glazed. The humidity and cold make it worse. Pull the drums and scuff the braking surface with a scotch brite pad and do the same to the face of the shoes. Hose it all down with brake clean and put it back together. good to go....
Thanks for your advice. The wheel bearing was loose on one side. Sounds better now. Took the opportunity to repack the bearings and paint the wheel wells with undercoating as some of my dearly departed subarus have started leaking there.Found some cancer while I was down there......darn  its started already
