Reidy Posted August 19, 2013 Share Posted August 19, 2013 Hi folks, this is my first post/topic, and I'm happy to find this great forum. We live in Northcote, Victoria. We own a great old 1993 Liberty AWD Station-wagon, and it suits our needs perfectly.In recent years the rear suspension has intermittantly failed...sometimes re-inflating after long drives. There is a control panel near the steering wheel, EP - S Height Control, that has flashed and blinked and sometimes has arrows going in both directions at times. Not sure if the problem is electrical or mechanical. The problem now is unbearable, and we would rather repair than throw the vehicle away. Can anyone suggest a cause, perhaps recommend a strategy, even direct us to an expert...any help would be much appreciated. Thanks in advance. Reidy Quote Link to comment Share on other sites More sharing options...
Olnick Posted August 19, 2013 Share Posted August 19, 2013 Welcome to the USMB, Reidy. Always nice to meet someone who would "rather repair than throw the vehicle away!" The first gen Legacy/Liberty is a great vehicle. The usual fix up here is to simply tear out the pneumatic suspension and replace with standard coil springs and struts, generally with parts from a salvage yard. It's been talked about a lot in the past--maybe you can find useful information with the "search" function. Hopefully someone with more suspension knowledge than I have will jump in with suggestions and links. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
heartless Posted August 19, 2013 Share Posted August 19, 2013 Olnick is correct - get rid of the air suspension (far too cost prohibitive to try to repair/replace) and put in standard struts & springs. Easily done with parts sourced from a junkyard or in the marketplace here on the USMB. I had to do this with my 1990 LS wagon - the rear air struts were completely shot when I got the car. (your picture looks exactly like my car - right down to the color! only yours is in much better condition LOL) Parts list consists of: Struts, coil springs, & top hats (upper strut mounts) to fit your car. You should be able to source the complete assemblies (all the mentioned parts together) fairly easily. Please note that each is specific to a location - LF, RF, LR, RR Once you have all 4 assemblies - simply remove the air struts (a pair of side cutters make short work of the air lines), and replace with the standard coilover struts. You will need to remove the upper cover inside the car, over the rear wheel well. On mine it was a speaker grill & speaker that had to come out to access the strut mounting area - not sure if yours still has the rear speaker in that location - but if it does, just pop the upper cover off (the grill portion should be a seperate piece) then unscrew the speaker, disconnect the wires and set the speaker aside...there are 3 studs/nuts that hold the upper mount in place & 2 bolts that hold the lower end. On the front lowers - mark the position of the upper bolt - it is a cammed bolt that adjusts camber - by marking its position, you can get it put back in pretty much the exact position it was in avoiding the need (and cost) to have an alignment done. to prevent the compressor from kicking in - there should be a small control box under the drivers seat that controls the air system - simply unplug it (there may also be an associated fuse in the fuse panel - it has been about 6 years since I did mine, so I dont remember everything). compressor is hidden behind the left front fender - if you feel ambitious, you could remove the fender and take it out - I just left mine in place - it isnt hurting anything by being there. The button on the dash is still in place as well, it just doesnt do anything anymore. by making the switch to standard coilover struts, it also gives you the option of adding a little extra height by using Forester struts/springs - but you would still need to have the correct top hats for your car. 1 Quote Link to comment Share on other sites More sharing options...
Terry in Australia Posted August 19, 2013 Share Posted August 19, 2013 G'Day Reidy, I live in Mill Park mate, and coincidentally I've just been looking at upgrading the suspension on my 95 Liberty. I found this site, and in the "Kings Springs" catalogue, there's a listing for a conversion kit for your car, to convert it to conventional shocks and springs. here it is here. Cheers, Terry. http://www.wholesalesuspension.com.au/products.html http://www.wholesalesuspension.com.au/pics/products/catalogues/kings_master_catalogue.pdf 1 Quote Link to comment Share on other sites More sharing options...
