spacesalmon Posted August 21, 2013 Share Posted August 21, 2013 (edited) Well I'm still pretty new to the community but I've read many different posts and I have traced vacuum lines and all are connected. The lights are on but I'm pretty sure it's not in 4wd. I say this cause the other day I got the front tire to slip on a paint mark at a red light. I have this connector down by my feet next to the door that has some wires ripped out (will get a picture as soon as possible) and I'm going to fix this and see if that helps but if anybody has any other explanation or a post that can help please do! Thanks again! Edited August 21, 2013 by spacesalmon Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 21, 2013 Share Posted August 21, 2013 (edited) I take it you have a pushbutton 4wd? Try reversing the vacuum lines from the trans diaphragm on the solenoids as it may be connected backwards. IF the solenoid is not working, you can manipulate the 4wd off and on by reversing the lines each way. otherwise there could be a short in the 4wd (sensor) switch on the trans If it is not any of that, maybe one of the rear axles is broken. Edited August 21, 2013 by MilesFox Quote Link to comment Share on other sites More sharing options...
spacesalmon Posted August 21, 2013 Author Share Posted August 21, 2013 (edited) Also what type of fluid should I put in the transmission? I saw 75w90 but cannot be limited slip but all I can find is limited slip lol. Still diagnosing the 4wd. Yes it is a push button and I have messed with the input shaft on the transmission could you possibly tell me which is 4wd and which is 2wd forward or backwards on the pivot? Edited August 21, 2013 by spacesalmon Quote Link to comment Share on other sites More sharing options...
MilesFox Posted August 21, 2013 Share Posted August 21, 2013 All the way forward would be 4wd and all the way back would be FWD Quote Link to comment Share on other sites More sharing options...
