Idleing high 1980 brat
When was the carb last rebuilt? Indescriminately changing the fuel-air mixture ratio may compound your issue. Do you have a FSM? If it is randomly kicking into a high idle start with examining the electric choke. If it will not idle under 1200 rpm your problem may stem from clogged idle jets, bad fuel mixture, incorrect timing. Verify the PCV valve and hoses are clear.
Years back picked up a great condition low mileage GL hatchback for a few bills because it wouldn't idle and could not be driven over twenty mph. The cause was a bad PCV and clogged breather hoses.
Carb was just rebuilt due to a sputtering issue and it idled before so im not sure whats wrong i may have did something. But it runs great just wont run below 1200 or idle an randomly its like the rpms hang when u shift or it high idles bad any help would be appreciated im lost
Take off top of carb and unscrew them doubt is you problem check intake gaskets are they factory subaru only ? also check that choke is pulling off and idle curcit in carb have had luck putting my hand over the top at high rpms thiss will stall it but pulls the crap outa the bottom of carb may have to do it more than one time but seems to work on old hitachis
There are two vacum lines in the front but dont feel like they have any vacum or suction on em? One goes into carb by a nipple
Are you saying that the two vacuum ports on the front of the carb are not being used and are not capped?  Both ports should have a nipple btw.
If the idle mix screw has no effect on the idle quality or speed, and everything else is intact, then it means you have by-passed the idle-circuit in the carb.  The idle mix screw should be roughly two full turns out from being lightly seated plus or minus a half turn.
Most likely you have some vacuum leaks.  If you messed with the fast idle screw on the carb, that can complicate matters as well.
Since you rebuilt the carb and idle/driveability issues still persist, you probably need to check all vacuum lines coming off the manifold (brake booster, charcoal canister valve, canister purge line, etc,..) as well as the intake manifold gaskets.
Does the behavior change as the engine warms up?
Edited by ferox
