92 Loyale Bad ECU?
ecu egr loyale cel 34
8 replies to this topic
#1 koticimage
koticimage
    Newbie
  • Pip
  • 6 posts
  • California
Posted 25 August 2013 - 04:55 PM
I need a little help. I have a 92 4wd Loyale Wagon that I need to smog in. Runs great but the CEL is on.  Just drove 850 miles and got an average of 34mpg.  Hooked the green test cables up on the driver's side in the engine bay and shows a code 34.  I jumped the cables at the EGR solenoid, as described in this forum along with disconnecting the battery to clear the codes.
No change, the CEL is still on.  Does this mean the ECU is bad?
#2 l75eya
l75eya
    Almost has it all figured out
  • 2,371 posts
  • Hoboken, NJ
Posted 25 August 2013 - 05:56 PM
Means you need to replace the egr solenoid
#3 Gloyale
Gloyale
    It's a sickness
  • 10,929 posts
  • Corvallis, OR PNW
Posted 25 August 2013 - 06:05 PM
You can install a resistor (33ohm) across the solenoid connector this will turn the CEL off, but probably won't pass smog like that unless they just don't notice.
#4 koticimage
koticimage
    Newbie
  • Pip
  • 6 posts
  • California
Posted 25 August 2013 - 06:18 PM
Thanks for the quick response. Does it have to be a certain wattage? My local Radio Shack only has the 1/2 watt ones, will these work? http://www.radioshac...oductId=2062312
#5 Gloyale
Gloyale
    It's a sickness
  • 10,929 posts
  • Corvallis, OR PNW
Posted 25 August 2013 - 06:19 PM
1/2 watt is fine.
#6 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 26 August 2013 - 12:44 AM
Could also be a wiring issue. Thought I had a bad ECU when I couldn't figure out my IAC code... turned out it was the wires right at the plug on the harness side. If I moved the wires, it was golden.
I'd check the wires at the plug back to the ECU or at least the main harness bundle at the driver's side head...
#7 koticimage
koticimage
    Newbie
  • Pip
  • 6 posts
  • California
Posted 26 August 2013 - 01:27 AM
Thank you for your suggestions, I have pulled the ECU and examined the wiring that I could see along with the ECU pins and they all seem ok.  I'll head over to Radio Shack in the morning to pick up some resistors and see if that works.
#8 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 26 August 2013 - 09:46 AM
I use the soiliniods from newer outback/legacy do the same job but way tougher use 2.5d egr soiliniod
#9 koticimage
koticimage
    Newbie
  • Pip
  • 6 posts
  • California
Posted 26 August 2013 - 01:48 PM
No luck, tried the 33 ohm resistors and didn't work.  Any other ideas?
