ej trans swap Qs?
2 replies to this topic
#1 TOI
TOI
    New User
  • PipPip
  • 21 posts
  • Sherman,
Posted 26 August 2013 - 08:28 PM
right so i am currently parting out my 93 impreza wagon to donate its trans and the ej22T for a GL project that i would like to get on buying/building. i've read that with the xt6 xmembers and a impreza center i can run my ej trans. but will my shifter linkages and shifter still work in the GL? and does the impreza driveshaft bolt to the GL rear diff? it'll be a rwd project and i dont want to swap rear diffs unless its really a good idea and worth the extra trouble.
thanks
-ian
#2 Turbone
Turbone
    The Original Rob
  • Moderator
  • 12,191 posts
  • WA
Posted 26 August 2013 - 09:35 PM
You will need to do some modifying on the linkage mount to body. I just used a strap on mine.
You will need to get a driveshaft shortened (I think its shorten).
#3 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,151 posts
  • Oregon City
Posted 28 August 2013 - 12:06 AM
I found a small strap, I think from a parking brake cable and bolted it in to hold the end of the linkage. Like Rob said, you'll need to shorten the front half of the driveline 55mm. Easiest way to bolt it to the car is using XT6 5-speed front and rear transmission cross members and the EJ center section. This will only work if you have a late '87 and newer GL only build date will know for sure.
I found that my earlier built '87 GL coupe had a smaller transmission tunnel in it. The transmission fit fine however I had no direct bolt in crossmembers. I was in the middle of modifying a 3AT crossmember to bolt to the EJ center section when I came across my newest shell.
