jojomish Posted September 2, 2013 Share Posted September 2, 2013 (edited) starts good. when engine gets warm it starts misfiring, cant give it any fuel, it stalls but will restart just cant touch the accellerator. codes-P0446, P01507, P0102 Edited September 2, 2013 by jojomish Quote Link to comment Share on other sites More sharing options...
NorthWet Posted September 2, 2013 Share Posted September 2, 2013 (edited) Model, year and engine type (if known) would be useful information. Edit: Never mind... saw the info in the post tags. 1999 Outback 2.5. Edited September 2, 2013 by NorthWet Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 2, 2013 Share Posted September 2, 2013 (edited) We had a 98 forester do this, you had to feather the throttle to get it going, it would stall. We tried replacing the spark plugs at no avail. It turned out the be the MAF and it was cured replacing it with a junkyard unit. (ej25d DOHC) Edited September 2, 2013 by MilesFox 1 Quote Link to comment Share on other sites More sharing options...
luko Posted September 3, 2013 Share Posted September 3, 2013 Has to be some sort of a sensor with it only happening when it warms up or in closed loop operation. Like MilesFox said it could be the MAF Quote Link to comment Share on other sites More sharing options...
jojomish Posted September 4, 2013 Author Share Posted September 4, 2013 Thanx folks. I unplugged the MAF and the engine stalled immediatly. Plugged it back in and has been running fine today.???? Nothing ever just goes away though!! OBD still giving me the MAF code though. Bought a knocker sensor today. Shopping 4 the MAF also,. Thanx again Quote Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 4, 2013 Share Posted September 4, 2013 should be able to pull the maf from the intake and spray-clean it with CRC MAF cleaner. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted September 4, 2013 Share Posted September 4, 2013 Clear the code, as un plugging the MAF would have tripped it and stored it. Use an obd2 scanner, or disconnect the battery to clear it.. Perhaps the connector was loose or corroded? Sometimes just wiggling a connector can slve problems. Get some electrical contact cleaner and some dielectric grease. 1 Quote Link to comment Share on other sites More sharing options...
jojomish Posted September 6, 2013 Author Share Posted September 6, 2013 thanx milesfox ! unplugged and cleaned A0K-K so far Quote Link to comment Share on other sites More sharing options...
