Frankenmotor: which timing belt... Stupid Question, Couldnt find the answer..
4 replies to this topic
#1 xbeerd
xbeerd
    dookin'
  • 1,023 posts
  • Milwaukee, WI
Posted 05 September 2013 - 02:00 PM
How many teeth should the timing belt have for a frankenmotor setup?  i looked on Rock auto,  they listed a 223 tooth belt for a 99 sohc 2.2l and a 211 tooth belt for a 95 2.2l.   im running 99 2.5block with 95 22heads
currently im just running the belt that was on the junkyard '95 ej22.
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,023 posts
  • East Coast
Posted 05 September 2013 - 02:15 PM
and how is it running?
match the timing belt to the heads.  picture the blocks as all being identical - so heads determine the belt.
#3 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 05 September 2013 - 05:09 PM
from what i have read,
the belt matches the heads.
so you are running the right one.
#4 xbeerd
xbeerd
    dookin'
  • 1,023 posts
  • Milwaukee, WI
Posted 06 September 2013 - 08:52 PM
ok, thanks for the clarification.  makes sense that it should match the heads if the blocks are all identical.
its running well but i wanted to replace the belt just cuz the one on there has been sitting in a junkyard for a couple years on a shelf
#5 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 06 September 2013 - 09:29 PM
Shmaus' frankenmotor uses the ej22e belt with ej22e heads. I got a whole timing belt and cam seals in a box as leftovers. If you want it, let me know. I do not have pulleys, though. snag it up for whatever it is worff to you.
