rear drum shaft loose
2 replies to this topic
#1 thecrazyslopoke
  • Pip
  • 8 posts
  • wenatchee WA
Posted 05 September 2013 - 08:08 PM
i dont actually know what its called but i was replacing my rear cv and was having some some trouble getting the outside to come off and ended up hitting that shaft that runs through the drum assembly with a hammer to see if it would help. it didnt. i got it off and the new axle installed but now that shaft is wobbly. tightened down the castle nut and still is really loose. so if anybody know what that shaft is actually called so i can order a new one or if you have any suggestions for me it would be appreciated
#2 MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 05 September 2013 - 08:18 PM
The axle nut requires some 145 lb torque as it is not a spindle bearing. The flat washer is a spring washer and should be installed with the convex side towards the nut tot hold torque.
IF 145 lb doesnt draw the shaft through or hold the wheel tight, the bearing likely has failed (busted cage)
#3 spazomatic
    USMB is life!
  • 461 posts
  • castle rock
Posted 06 September 2013 - 08:34 AM
Sounds like the bearing is shot. What year's your ride?
