99 forester parts fit 95 sedan
Parts
2 replies to this topic
#1 86subaru
86subaru
    Elite Master of the Subaru
  • 3,097 posts
  • ohio
Posted 15 September 2013 - 07:46 AM
Whats parts will fit and work from a 99 forester to a 95 2 doorl.
#2 Rooster2
Rooster2
    Subaru Master
  • 4,679 posts
  • Indianapolis
Posted 15 September 2013 - 11:13 AM
No body parts are interchangeable. What will interchange is motor, tranny, suspension parts. My 99 OBW has a front suspension knuckle from a 99 Forester, that I got from a wrecking yard.
#3 johnceggleston
johnceggleston
    Lite Master of the Subaru
  • 6,712 posts
  • Virginia
Posted 16 September 2013 - 09:51 AM
the engine in the 99 forester is a phase 2 SOHC ej25,
it will not swap into a 95.
the trans will not swap UNLESS you used the matching rear diff as well.
so you are limited to wheels, knuckles, spindles, struts, axles, brakes, wheels, tires, and maybe some of the drive shaft.
but there are conditions on some of the above parts like,
larger brakes require larger wheels.
larger tires require taller struts.
the 99 forester is not a good choice as a parts car for a 95 lego.
a 96 - 98/9 outback would be a much better choice.
Edited by johnceggleston, 16 September 2013 - 09:56 AM.
