Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Shift-shock when changing gear (automatic 4 speed)
#1
Posted 15 September 2013 - 06:06 PM
I own a 2008 impreza RX - 2 litre standard, 4 sp auto hatch with 50,000 km - actually my wife's car and driven as though it belongs to God.
Recently, when the auto changes gear, there is a thump felt that actually shakes the car. When slowing down, the gear changes again provide some shift-shock but to a lesser degree.
The Subaru dealer's mechanic drove it and experienced it but his computer analysis shows no faults. Can anyone offer meaningful advice ? The next stage is evidently to take out the gearbox and ship it off to specialists to have it diagnosed and repaired. Quotes at this stage are rubbery but $2,000+ is being discussed. In a modern car with 50,000 gentle km????
Help!
Kind Regards
Thomas
#2
Posted 15 September 2013 - 10:18 PM
check the negative battery terminal. seems random, but when i replaced my corroded, rusted out negative battery terminal it fixed that very same problem in my wife's 4EAT!
best of luck!
#3
Posted 15 September 2013 - 10:21 PM
Subaru should pay for this one .
#4
Posted 16 September 2013 - 10:33 PM
Welcome to the USMB. I'm going to move your post to the new gen forum. It should get some additional comments there.
#5
Posted 19 September 2013 - 06:38 AM
a "computer analysis" is not going to show a failing axle joint, failing carrier bearings, failing u-joints in the driveshaft, bad struts, worn bushings, fluid level & condition....
there are a lot of other possibilities besides the tranny itself going bad (which does not happen that often), including the one mentioned above about the corroded battery cable...
did the dealer shop put the car up on a lift and actually physically inspect the driveline components? If not, I would be finding another shop...
Edited by heartless, 19 September 2013 - 06:39 AM.
#6
Posted 08 October 2013 - 05:32 AM
Kinda sounds like what my car is doing. Have had the problem for years and no one has been able to figure it out. It will shift at the wrong times. Varys a bit but will drop gears with a thud feels like being rear ended always when coasting on flat ground often going slow or slowing down. Does your oil at temp light ever come on? Mine will also shift when the rpms are too high. If I pull over turn off the car and press the gas twice it will usaully stop.
Also tagged with one or more of these keywords: Shift shock, transmission problem
Newer Generations of Subaru discussion →
1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVX →
2000 Legacy Automatic Tranmission ProblemStarted by Rhyno12 , 05 Feb 2016 ![]() |
Transmission ForesterStarted by Napzed , 26 Jun 2015 ![]() |
