EA71 lift
8 replies to this topic
#1 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 16 September 2013 - 09:47 AM
I know lift kits for EA71 vehicles are a bit "interesting" because of the rear suspension.After looking at the rear of my 78 brat it doesn't look as though bigger tires can easily be fitted without the tires rubbing on the suspension.So I was wondering if there is a lift kit that swaps in EA81 rear suspension?I can certainly build one and incorporate it with a 4" lift,but for the time being it might just be easier to find a lift kit that does that...So are there any lift kits that swap in EA81 suspension?BOSS,SJR,ETC?
#2 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 16 September 2013 - 03:27 PM
I can do a custom one if you like
#3 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 16 September 2013 - 03:33 PM
How much would that run for just the rear blocks to swap in a EA81 torsion bar?
#4 bonvo
bonvo
    USMB is life!
  • 384 posts
  • LaPine, Or
Posted 20 September 2013 - 08:05 PM
someone on here already makes a lift kit for these my question is why would you want to change the rear suspension? keep the same wheel offset and your fine maybe go with a 0 offset or negative that way the wheels stick out 2 advantages to this one the car is wider so more stability and 2 moves everything away from the wheel
#5 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 22 September 2013 - 09:57 AM
Mainly just to remove interference from the back tires rubbing on the torsion bar.
#6 bonvo
bonvo
    USMB is life!
  • 384 posts
  • LaPine, Or
Posted 01 October 2013 - 01:59 AM
thats just wheel choice man if your gonna lift it use chevy 6 lug rims with negative offset problem solved
#7 Uberoo
Uberoo
    Subaru Wheeler
  • 3,862 posts
  • lewiston,ID
Posted 01 October 2013 - 05:19 PM
Even with negative offset wheels the tires will still rub on the pivot point.I'm gonna be running a 8" lift and 31" tires.
#8 Singleactioncolt
Singleactioncolt
    Member
  • PipPip
  • 13 posts
  • Alexandria, LA
Posted 02 October 2013 - 10:33 AM
how much would that cost?
#9 Scott in Bellingham
Scott in Bellingham
    Lets go wheelin!!
  • 4,045 posts
  • Bellingham
Posted 02 October 2013 - 02:04 PM
$800-$1000  depending on height
