The Scooby Posted April 24, 2004 Share Posted April 24, 2004 well tonight on the way home i stoped at my usual place i hit the mud puttles and then the ditch that i go through, well i go through the dirch, then put it in 4LO and hit the mud, shift into second and pull out. i go to put it into reverse after commign to a stop to get through the mud again and it wont go in reverse, just grinding. i then decide to leave, ends up all the lower gears meaning, 2, 4, and Reverse wont work, i can go through 1, 3, 5th no problems, but i cant get it into the others while driving or stopped. but when its not running sitting still i can shift easily like i was able to before through all the gears. i have to go to work tomarrow so can someone give me some hints to what i have to do to fix this. Thanks, Shean Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted April 24, 2004 Share Posted April 24, 2004 If it's grinding, then it could be that your clutch is not fully disengaged - maybe you got some dirt in there.... if that isn't your problem, then I'm sorry to say that your transmission is probably gone. That said, it sure sounds like the clutch, since it goes into gear while not running. GD Quote Link to comment Share on other sites More sharing options...
The Scooby Posted April 24, 2004 Author Share Posted April 24, 2004 ya sitting witht he motor off i can go through all the gears no problem, then if i start it up i can hardly shift into 1,3,5, but 2,4 is hard and i almost have to force it, and there is absolutly no way into reverse, it just wont allow me, all it does is grind, even when it is ideling and i try to gently push it in, no dice. this sucks, Shean looks as if im not only rebuilding the engine but also putting in a new tranny after i get my brat. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted April 24, 2004 Share Posted April 24, 2004 Leaning towards clutch malfunction here, too. Possibilities are: Cable streched, but that would be streching it a bit. Throw-out lever, either bent, broke, or came off of the pivot, or off of the throw-out bearing. Clutch disc, either it's hanging up on the input shaft of the tranny, possibly do to mud/dirt on the splines, or the disc failed and has wedged the clutch material between the disc and the flywheel/pressure plate, not allowing the clutch to fully release. Quote Link to comment Share on other sites More sharing options...
The Scooby Posted April 24, 2004 Author Share Posted April 24, 2004 ok so a bad clutch is causing it to not let me shift into the lower gears meaning 2,4,r, wouldnt taht make it so i cant shift into any at all?? oh well looks as if im going to have to put in a new clutch and cable. Quote Link to comment Share on other sites More sharing options...
GLCraig Posted April 24, 2004 Share Posted April 24, 2004 Have you tried adjusting the clutch cable yet? Also inspect your tranny mounts and linkage. Quote Link to comment Share on other sites More sharing options...
The Scooby Posted April 24, 2004 Author Share Posted April 24, 2004 yep i did ajust the cable last night, no change, then when i got home i checked the linkage, its fine also. so i dunno, ill check the mount today, but it looked fine last night also. im just going to take it up to Brian's Subaru up here in Burien monday morning, have a new clutch put in anyways since this one slips, and have them check everything else. Shean Quote Link to comment Share on other sites More sharing options...
TomRhere Posted April 25, 2004 Share Posted April 25, 2004 Ahh, another piece of the puzzle has been put into place. Now, was the clutch slipping before this, or is it slipping now afterwards? Quote Link to comment Share on other sites More sharing options...
Turbone Posted April 25, 2004 Share Posted April 25, 2004 Its most likely you have some junk in the linkage. Get under the car and check to see if theres a rock or stick or other stuff in the tranny tunnel. Quote Link to comment Share on other sites More sharing options...
WJM Posted April 25, 2004 Share Posted April 25, 2004 That and take a pressure washer, or do a really good job with a regular hose, and wash out the area for the linkages, and with the engine stopped, flush the clutch area...although all may dissagree, due to contamination the water may impose on parts in there...but its something to try before spending $ on a clutch job at a shop...even tho its time for one, why not try to go a little further on this one? Quote Link to comment Share on other sites More sharing options...
The Scooby Posted April 25, 2004 Author Share Posted April 25, 2004 it was slipping before this happened, and if i ajusted it lets say monday, by wednesday i would have to reajust it, when i first got it you could shift into second spinning the tires, now it just slips alittle, and no sticks/rocks in the linkage... oh well i say get drunk tonight then take it to brians tomarrow and have the kevlar clutch put in and a complete tune up, i got the money, might as well have the work garuntied. ya know... Later, Shean Quote Link to comment Share on other sites More sharing options...
WJM Posted April 25, 2004 Share Posted April 25, 2004 Sounds like a deal. How much for that clutch disc? Quote Link to comment Share on other sites More sharing options...
The Scooby Posted April 26, 2004 Author Share Posted April 26, 2004 dunno, they arent open on weekends, so im going to take it up tomarrow morning and see how much. might as well have them put in my cam seals and a new water pump while they are at it. i just dont have the time to. Shean Quote Link to comment Share on other sites More sharing options...
