My '95 Legacy heater/ac fan only runs on high the high speed. I read on here somewhere that there is a resistor (or something) that could be bad, possibly mounted behind the glove box. Can anyone clear this up for me and tell me what exactly I need to replace and where it's located? Thanks.
Welcome to Ultimate Subaru Message Board, an unparalleled Subaru community full of the greatest Subaru gurus and modders on the planet! We offer technical information and discussion about all things Subaru, the best and most popular all wheel drive vehicles ever created. We offer all this information for free to everyone, even lurkers like you! All we ask in return is that you sign up and give back some of what you get out - without our awesome registered users none of this would be possible! Plus, you get way more great stuff as a member! Lurk to lose, participate to WIN*!
* The joy of participation and being generally awesome constitutes winning ** Not an actual guarantee, but seriously, you probably won't regret it! Serving the Subaru Community since May 18th, 1998! |
Heater/AC fan only runs on high, how do I fix?
Started by
Brettm57
, Apr 24 2004 06:22 AM
5 replies to this topic
#1
Posted 24 April 2004 - 06:22 AM
#2
Posted 24 April 2004 - 12:59 PM
you need to rplaced your blower motor resistor. when the resistor fails it can only operate the blower motor at full speed. it is easy to replaced, its right nearthe blower motor.
#3
Posted 25 April 2004 - 11:59 PM
I've never taken mine apart in the subie, but usually, the resistors are usually located inside the ducting (to cool the wire coils) by the motor. They would probably be mounted on the same piece that the power for the blower fan connects to.
Maybe someone else can chime on on exact location, but you shoul be able to find it just by checking around the area by the motor.
#4
Posted 26 April 2004 - 12:11 AM
If I remember correctly (in my XT6) when you remove the panel on the passenger side <under the glove box> (for the 6) there was a black box to the left of the blower motor held in by 2 screws. Undo the screws and pull out the box. Its got coils on it and some gray stuff on the coils (stuff is hard, but easy to crack...so be careful). Sorry but that's all I got, maybe someone can help more.
#5
Posted 26 April 2004 - 05:55 AM
Now I have to ask the really dumb question, where is the blower motor located on a Legacy? Then maybe I can track down those pesky resistors!
#6
Posted 26 April 2004 - 10:50 PM
It's right above the passenger's feet. Push the passenger seat all the way back to give yourself some room to work, then take off the kick panel underneath the glove box. You should seen the outside of the blower motor, and it has a big wire bundle coming out from it (4 wires in a cable). These 4 wires go to the unit you are looking for, the resistor block. As others have described, carefully take it out, and you'll see the resistors which are actually wire coils (very low resistance). These wire coil resistors sit in the windstream created by the blower motor. As a side note... if your blower motor ever gets bad bearings and slows down, the first thing to go then will be one of those little resistors, because it won't get cooled enough. I got a new resistor block from someone one Ebay. They are available... good luck!
