joking41 Posted September 28, 2013 Share Posted September 28, 2013 since the first day iv'e had my Subaru the gas gauge hasn't worked. iv'e done a few tests and it seems like the fuel sender no ohm's are coming from the sender. i have power to the sender and a good ground. if anyone has a fuel sender laying around that works id be more then grateful to buy it. let me know if im wrong about my presumptions. Quote Link to comment Share on other sites More sharing options...
TomRhere Posted September 28, 2013 Share Posted September 28, 2013 What model/year? 1 Quote Link to comment Share on other sites More sharing options...
coxy Posted September 30, 2013 Share Posted September 30, 2013 Pull the sender and make sure the contact is making a Good connection as it sweeps over the rheostat section, Often simply bending the contactor arm will fix things by making a decent contact once more they are a simple mechanical system when all said and done no electronics involved so an eyeball will show you what is needed to hopefully fix the issue. Quote Link to comment Share on other sites More sharing options...
Mykeys Toy Posted October 1, 2013 Share Posted October 1, 2013 The connection would be the first thing to check.. The sender almost never actually dies which is good since you cannot get them anywhere. The next most likely culprit is the gauge itself. That also can be checked But I am not the one to tell you how.. The gauge was the problem in my 83 GL. Quote Link to comment Share on other sites More sharing options...
Corvid Posted October 1, 2013 Share Posted October 1, 2013 I've got a pullled EA82 unit I can sell you for a couple bucks, but I bet when you dig it out to replace it, you'll see what needs to be cleaned up or bent back into place on yours. I've looked at more than one where the contacts were green and crunchy when we finally went to go examine the sender. Quote Link to comment Share on other sites More sharing options...
superpoo93 Posted October 2, 2013 Share Posted October 2, 2013 Now here is another option if cleaning does not work. http://www.tristarrradiator.com/ Quote Link to comment Share on other sites More sharing options...
superpoo93 Posted October 5, 2013 Share Posted October 5, 2013 I found this also price is much better. Around $60 http://www.subarupartslive.com I cleaned mine and adjusted it works great. Quote Link to comment Share on other sites More sharing options...
