wrx rear caliper on XT6?
7 replies to this topic
#1 Marck
Marck
    Certified Subaru Nut
  • 776 posts
  • Nipomo
Posted 03 October 2013 - 12:47 PM
I am sure someone on here already compared wrx rear brakes to xt6 rear brakes.
Will the WRX rear caliper mount to the XT6 rear caliper bracket or will the WRX rear caliper with bracket mount to the XT6 backing plate?  If not, how close is the mounting bolt spacing between the two?
#2 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,096 posts
  • East Coast
Posted 03 October 2013 - 01:53 PM
no, they don't fit.
#3 capn_r
capn_r
    Pseudo Soob Noob
  • 363 posts
  • Morton WA
Posted 03 October 2013 - 02:52 PM
The WRX caliper mount can be adapted to the XT6 (not a bolt on) and once it's mounted you can run the WRX brake components on the XT6 hub. IIRC the center hole is larger and the bolt pattern is different so a spacer to keep it centered and then sort out the mounting holes.
#4 Marck
Marck
  • 776 posts
  • Nipomo
Posted 03 October 2013 - 05:25 PM
When you say center hole, are you talking about the rotor which slides onto the 56.1mm hub?  Can the rear XT6 rotor be used with the wrx caliper once adapted?
#5 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 03 October 2013 - 07:29 PM
No, he's talking about the center hole in the backing plate. The GC/GD one is larger... someone (maybe Nico ?) Has done it..
#6 Marck
Marck
  • 776 posts
  • Nipomo
Posted 04 October 2013 - 04:58 AM
Hmmm, do you need the dust shield from the WRX?  I thought the caliper mounts to the hub, vice backing plate.  In other words, the attachment point for the caliper bracket is part of the hub (1 piece of metal).  So I was thinking that I have to keep the XT6 backing plate and modify that along with the caliper bracket to mate the two.  Then I would have to figure out what rotor works best.  Is this right?  And let's not even get into the e-brake.
#7 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 05 October 2013 - 08:48 AM
Borrowed from Nico, in the B/S/T Forums...
These are the 2 piston STi rear setup from a GC8 (same rear spindles).
Notice how the bracket mounting holes are in the backing plate? This isn't 18 gauge steel. This is like 1/8 thick stuff.
On 4WD rear arms (on the EA82), the bearing housing (the sleeve the bearing sits in) has a smaller diameter than that center hole of the backing plate on the GC platform so you have to do something (making a hub centering ring seems the easiest).
#8 Caboobaroo
Caboobaroo
    USMB Drunk
  • 7,157 posts
  • Oregon City
Posted 05 October 2013 - 02:36 PM
But the gap is only 1/8" at most. I modified a set of WRX backing plates to bolt onto my XT6. I ended up slotting two of the original holes in the backing plate to accept the different bolt pattern and then drilled a new hole for the rear bolt with nut. I still plan to reinforce the areas around the "new" holes to make them more precise but haven't had any issues since I converted it to the rear ebrake setup.
