At wits end! 1990 Legacy won't keep running in rain
9 replies to this topic
#1 hansonworld2003
hansonworld2003
    Newbie
  • Pip
  • 1 posts
  • Conifer CO
Posted 04 October 2013 - 02:21 PM
1990 Legacy wagon starts up, drives for about 30 minutes in rain or wet snow, then starts misfiring and dies. Will  start right back up, but acts as if not running on all cylinders. Tach all over the place but no power.  Can sit for awhile, then nurse it a couple more miles and it dies all over again.
Replaced spark plug wires, fuel pump.
Is there a crankshaft position sensor that could be getting wet?
Suggestions?
#2 Rooster2
Rooster2
    Subaru Master
  • 4,723 posts
  • Indianapolis
Posted 04 October 2013 - 03:00 PM
coil pack??
#3 TOONGA
TOONGA
    I divided by zero
  • 193 posts
  • Australind
Posted 04 October 2013 - 06:08 PM
it could be the coil pack  or the ignition relay(well hidden under the dash orange relay) or the igniter(under bonnet) Have you checked for codes?
TOONGA
#4 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 04 October 2013 - 11:13 PM
Get it warmed up one night and most some water (spray bottle) on the coil pack, look for sparklies.
#5 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
  • North Central Wisconsin
Posted 05 October 2013 - 08:55 AM
Get it warmed up one night and mist some water (spray bottle) on the coil pack, look for sparklies.
Do this ^   waiting until after dark makes the spark easier to see.
Also mist a little water around the spark plug end of the wires. If you used a cheap set of wires you could have one that is jumping spark to the block. I had that happen to me before on my 1990 EJ22 - it was so bad that I could see it in broad daylight! Had to wrap the boot with electrical tape to get to where I was going & get another set of wires. No more cheap wires for me!
the crank & cam sensors should not really be affected by moisture unless the housings are cracked/damaged (pretty rare)
Do you have a CEL on? (does it even work?) If so, finding out what the code is would be big help in diagnosing.
#6 LosDiosDeVerde86
LosDiosDeVerde86
    1000+ Super USER!
  • 1,359 posts
  • Columbus
Posted 07 October 2013 - 02:45 PM
I had a similar problem with my 96 years ago and it was water getting into the MAF. I replaced the MAF and put the sound deadeners back in and it never happened again.
#7 later_Peter
later_Peter
    Advanced Member
  • PipPipPip
  • 57 posts
  • Central Oregon
Posted 07 October 2013 - 03:41 PM
I had this problem (a while back) with a Datsun PickUp Truck... spark plug wires.
#8 Gloyale
Gloyale
    It's a sickness
  • 10,835 posts
  • Corvallis, OR PNW
Posted 08 October 2013 - 07:46 PM
Spark plugs + wires or maybe a Cam Position sensor.
All 3 are easy to swap out to check.
#9 nipper
nipper
    Semi Elite Master of the
  • 18,195 posts
  • Long Island NY
Posted 08 October 2013 - 09:17 PM
You can actually take a hose with a light mist and work your way around the engine compartment. Also do it UNDER the engine too kaing sure to get the engine temp sensor wire, and the cam and crank position wires
#10 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 09 October 2013 - 09:23 AM
Wire harness beside the battery in the fender well about 4 inch from fuse box is my gess broken or coroded wire
