Sturgeon88 Posted October 11, 2013 Share Posted October 11, 2013 (edited) I am new to the site so forgive me if I breached some etiquette by posting before introducing myself. I own a 1996 Subaru Outback Legacy and I recently brought it to the shop to have the clutch replaced. It was making a grinding noise that me and the mechanic both thought was the throw out bearing. So I got a new kit and had him replace it. When I showed up he showed the that the part of the disk that mounts to the transmission and holds the pads on had actually SNAPPED off. He reassembled it with the new clutch kit anyway and we took it for a test drive. The grinding noise had become much worse. So, that is where I am at. He thinks it is the bearing that guides the input shaft. I am very interested in your opinions and advice. The input shaft makes sense to me. Does anyone near Bend know of any parts around? What do you think I need? What do you think the problem is? Give me your thoughts. Edited October 11, 2013 by Sturgeon88 Quote Link to comment Share on other sites More sharing options...
lmdew Posted October 11, 2013 Share Posted October 11, 2013 Did he check the input shaft for play? I just dropped a trans out of an 01 Forester the inner hub of the clutch disk was completely severed from the outer disk. The shop that surfaces my flywheels said it looked like someone downshifted at high speed. The input shaft to the trans also had lots of fore and aft play. Used Trans going in along with a new Clutch Kit. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 11, 2013 Share Posted October 11, 2013 It's probably the main shaft bearing. When they get bad enough it lets the input shaft wobble all around and slide back/forth too much. Causes the center hub of the clutch disc to break. Easy way out is to replace the trans. The bearing is only about $50, but it takes a few hours to disassemble and reassemble the trans and put the new bearing in. Quote Link to comment Share on other sites More sharing options...
Sturgeon88 Posted October 12, 2013 Author Share Posted October 12, 2013 Exactly my problem Imdew. Im soft on my car but it shows that symptom. I've lost 3rd and 4th so the tran is shot. Do you think a used transmission is the way to go? I'll check the local yards, but do you have any other ideas of where to look online? Thanks guys, greatly appreciated. Quote Link to comment Share on other sites More sharing options...
lmdew Posted October 12, 2013 Share Posted October 12, 2013 Local used is the best. www.car-part.com is a good place to check full service yard prices, but shipping is expensive. Quote Link to comment Share on other sites More sharing options...
