1st and 2nd gen trans compatability
4 replies to this topic
#1 belacane
belacane
    USMB Regular
  • 364 posts
  • New Orleans, LA
Posted 13 October 2013 - 02:03 PM
Looking to do a d/r swap on a 1980 brat. Will a dual range trans from a 2nd gen brat from 1982 bolt up with 1st gen brat from 1980. I'm aware the that 1980 brat came as a single range. If any, what mods are needed to make the transplant work?
Thanks!
Edited by belacane, 13 October 2013 - 06:33 PM.
#2 SuperBrat
SuperBrat
    USMB is life!
  • 363 posts
  • north idaho
Posted 13 October 2013 - 03:57 PM
81 Brat with old body style had dual range 4x4 the 1980 did not.......
#3 Leeroy
Leeroy
    Old boxer tricks!
  • 629 posts
  • Albury, NSW, Australia
Posted 13 October 2013 - 08:06 PM
Firstly a 1980 Brat will have a top mount starter, all dual range transmissions are side mount starter... If you source a EA71 'fat case' bellhousing (side starter) that would be a start but there are still other issues such as the shifter linkages and in some instances the drivers DOJ might end up very close to the steering shaft. Having stated that, it has been done before!
Might be a good idea to search the forum for previous threads on this subject as it does come up fairly often.
#4 belacane
belacane
    USMB Regular
  • 364 posts
  • New Orleans, LA
Posted 13 October 2013 - 09:06 PM
Thank you Leeroy.
#5 Markus56
Markus56
    Whup tee do
  • 794 posts
  • Wolf Point, Montana
Posted 14 October 2013 - 05:57 PM
When i put a D/R in my '80 Brat, I ended up swapping everything over. I took out all the EA-71 stuff and replaced it all with EA-81. Engine, tranny, alternator, distributor, coil etc.
