2000 Forester L (118k)
11 replies to this topic
#1 FrothyLlama
FrothyLlama
    Newbie
  • Pip
  • 6 posts
  • Shoreham, New York
Posted 14 October 2013 - 09:38 AM
Hello, first post and possibly my first Subaru.
I'm looking at a 2000 Forester L with 118k miles. I'm taking it to my mechanic, but I did check out the bottom of the car, it had no rust. I also checked out the engine, and one thing I noticed was the passengers side axle boot was ripped down the crease, how much will this cost to repair and is there anything else I should check out on the Forester that it is known for?
#2 FrothyLlama
FrothyLlama
    Newbie
  • Pip
  • 6 posts
Posted 14 October 2013 - 10:27 AM
Just went to the mechanic, it will cost around $200 to fix.
#3 Rooster2
Rooster2
    Subaru Master
  • 4,687 posts
  • Indianapolis
Posted 14 October 2013 - 10:35 AM
Yea, $200 is the going price to replace a half shaft.
#4 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,033 posts
  • Grand Valley, PA
Posted 14 October 2013 - 10:36 AM
Not bad considering what some charge for labor on such things. You could do it yourself with fairly basic tools. If the axle is not clicking on turns, it can generally be re-booted, or just pay a bit more for the simplicity of replacing the axle itself. You'll hear a lot of opinions on OEM vs aftermarket axles. I've always used junk yard axles.
Welcome to the forum.
#5 FrothyLlama
FrothyLlama
    Newbie
  • Pip
  • 6 posts
Posted 14 October 2013 - 10:51 AM
Thank you for welcoming me, I might as well replace the whole axle while I have the money.
#6 okamikai
okamikai
    Advanced Member
  • PipPipPip
  • 68 posts
  • San Juan, Puerto Rico
Posted 15 October 2013 - 12:53 AM
Let me know if you need to know anything about Foresters, I have a 98 with 168k and I know almost everything about it
#7 FrothyLlama
FrothyLlama
    Newbie
  • Pip
  • 6 posts
Posted 15 October 2013 - 01:12 PM
Well, what are some of the things I should watch out for before buying?
#8 AdventureSubaru
AdventureSubaru
    Subaru Fanatic!
  • 2,033 posts
  • Grand Valley, PA
Posted 16 October 2013 - 06:34 PM
Apart from the usual look over - strong running engine, smooth shifting transmission, no structural rust etc. Check the heads for external leakage. Check the oil for signs of coolant mixing (looks like a milkshake)
Torque bind is fairly unique to AWD vehicles, while on a test drive, take some slow tight turns and feel for the car to shake and stutter. (Like a 4x4 in 4wd on pavement) indicating a torque bind issue.
Both issues are fixable if found, but are things you would want to know about before buying. Both repairs are a bit of a pain but can be done on a budget.
Edited by AdventureSubaru, 16 October 2013 - 06:35 PM.
#9 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 16 October 2013 - 07:17 PM
If it has 118,000 miles, make sure the timiong belt has been done. if not, you are due for it. replace it now if it hasn't been done. A good subaru mechanic will be able to tell if anything has been apart yet or not.
With the timong belt, have the water pump replaced.
Fluch and replace the coolant to prevent head gasket trouble (due to corrosion, the coolant has anti corrosive chemicals that wear out and need to be changed) If you understand electrolysis, you get the idea.
#10 okamikai
okamikai
    Advanced Member
  • PipPipPip
  • 68 posts
Posted 17 October 2013 - 12:18 AM
Catalytic Converters can clog over time depending on how those miles were done on the road, the axle boot thing is a curse of this cars; the engine and transmission mounts are prone to break, even aftermarket parts, this is what usually causes them to break. The boots could have been gracked because they were too old, but it's a fairly good millage. Also check what Fox said about the Cam Head gasket, I had to repair the entire engine because I didn't pay attention to the early signs of the issue.
#11 okamikai
okamikai
    Advanced Member
  • PipPipPip
  • 68 posts
Posted 17 October 2013 - 12:38 AM
Foresters didn't have step from factory, just the second color panel, it may have been possible that the late owner had installed a step on it. Great car you are buying, love her and she will love you back
#12 FrothyLlama
FrothyLlama
    Newbie
  • Pip
  • 6 posts
Posted 30 October 2013 - 08:35 PM
Sorry to bump the thread but, I ended up not getting the forester. It needed about $2000 in repairs, it's been a while so I do not remember what they were. Sticking with the Scoobys though.
