Need help PLEASE
10 replies to this topic
#1 turboloyale
turboloyale
    Member
  • PipPip
  • 18 posts
  • Deer Park, Washington
Posted 14 October 2013 - 01:23 PM
So I bought a 1990 Loyale Turbo and it is a clean car in and out. But its not shifting how it should. It will run up to 4500have rpms and shift from 2-3 and wont shift into 4the unless I'm going down hill at 80mph then it will go into od. I have looked for an answer to my problem but havent found anything to say what it may be except a vacuum hose not connected to the intake. Now there are two hoses not hooked to anything but there is nowhere to hook one to on the intake. Any help would be great. Thanks.
#2 john in KY
john in KY
    1000+ Super USER!
  • 1,638 posts
  • KY
Posted 14 October 2013 - 04:19 PM
This car has the 4EAT transmission. That vacuum hose isn't your problem because this transmission doesn't use it. Those two hoses are probably just vent hoses. The TPS could be out of adjustment and I would tinker with it first. Owned the same car years ago and loved it.
#3 turboloyale
turboloyale
    Member
  • PipPip
  • 18 posts
Posted 14 October 2013 - 05:42 PM
Ok I will see what I have can figure out with the tps
#4 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 14 October 2013 - 11:12 PM
Although the TPS could very well be the problem, it might also be dirty fluid, or possibly the "POWER" resistor unplugged. (edit: The POWER resistor would effect firmness of shift, but not when it shifted.)
Edited by NorthWet, 16 October 2013 - 01:05 PM.
#5 turboloyale
turboloyale
    Member
  • PipPip
  • 18 posts
Posted 15 October 2013 - 10:03 AM
Ok well I have gotten it to shift as it should, I think, but it is still flashing the "POWER " light 16 times. From reading other postings that is just saying something is up with the transmission. I'm trying to figure out the code retract process still.
The fluid is fairly new,3200miles, since the transmission rebuild. The motor was done about the same time. The guy I got it from sold it after his son passed and did not get everything back together in auto shop in collage. He transplanted the new motor and tranny.
#6 john in KY
john in KY
    1000+ Super USER!
  • 1,638 posts
  • KY
Posted 15 October 2013 - 12:01 PM
Flashing power light probably means a bad solenoid. Not familiar with the code retrieval process. Someone near you a few weeks ago had the transmission you need for sale. May want to search the for sale section.
#7 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 15 October 2013 - 01:05 PM
The one that I have used on the Loyale's 4EAT is a little bizarre and complicated.  I will see if I can find it.
#8 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 15 October 2013 - 01:11 PM
The following thread, post #4, gives the procedure that I have used in the past:
http://www.ultimates...des#entry479811
#9 turboloyale
turboloyale
    Member
  • PipPip
  • 18 posts
Posted 15 October 2013 - 09:34 PM
Thank You both for getting me some help on this problem. Thank You for the quick response too.
#10 rain_man_rich
rain_man_rich
    USMB Regular
  • 141 posts
  • Grants Pass
Posted 16 October 2013 - 12:52 PM
If you don't mind me asking, what did you do to make it shift better?
#11 turboloyale
turboloyale
    Member
  • PipPip
  • 18 posts
Posted 16 October 2013 - 10:24 PM
Well I have to admit I followed the recommendations of the others posting here. First I checked fluid level then I looked at how the TPS(Throttle Positioning Sensor) was aligned compared to a couple that I had took pictures of at my local pull-n-save. It was pushed all the way towards the fire wall, whereas the ones at the p-n-s were more towards the grill of the car. Once it started doing better I went ahead and followed the directions in my Chilton's manual to set it to the correct setting. Hope this will help you as it did me.
