1989 SPFI EA82 Code 55
11 replies to this topic
#1 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 14 October 2013 - 04:49 PM
My car is throwing code 55 EGR temperature sensor or circuit. I have checked and my egr is not stuck, and seems to be actuating under vacuum. I cleared the code and it came back. Searched and someone else said they replaced their ecu and that fixed the problem. Not sure about that, but that does not seem like a solution for me. Also this car was purchased new from Tennessee.
Edited by mike300z, 14 October 2013 - 04:50 PM.
#2 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 445 posts
  • Akron, OH
Posted 15 October 2013 - 10:31 AM
I'd drop the ECU and see if you can see any salvage yard marks on it.. may have been replaced with a Cali ECU.
Or could have been a Cali emissions-spec anyway.. Is there a sensor in or near the EGR valve? Would sort of look like a mini O2 sensor.
#3 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 15 October 2013 - 04:08 PM
The EGR code is caused by a problem in circuit/wiring of the EGR's vacuum solenoid.  This is a common problem, and the usual cause is a bad solenoid.  This solenoid is a little plastic box with 2 vacuum lines attached, and a pair of wires running to it.  The solenoid coil tends to fail.
Replace with another solenoid, or you can also replace the solenoid with a resistor of a specific resistance
#4 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 16 October 2013 - 06:56 AM
anyone have a solenoid for sale?
#5 ivans imports
ivans imports
    1000+ Super USER!
  • 2,954 posts
  • lumby bc canada
Posted 16 October 2013 - 09:14 AM
Use a outback one 90 % more reliabble and easy to find will have to modify wire harness but a good fix
#6 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 16 October 2013 - 11:07 AM
can you tell me more about this swap?
#7 Gloyale
Gloyale
    It's a sickness
  • 9,822 posts
  • Corvallis, OR PNW
Posted 16 October 2013 - 11:40 AM
Guys....it's the EGR temp circuit code, not the solenoid code.
The EGR temp circuit code would only be on cali spec models.  You need to check the manifold and see if there is a sensor there right at the base of the EGR.
If not, then that will explain the code.  Either manifold swapped into a Cali car, or more likely a Cali ECU swapped into the Tennessee car.
Just to be clear, it's actually lighting the CEL solid with a real code?  You aren't interpruting the model code flash of steady 5-5-5-5........which IIRC would be a manual, 49 state SPFI car.
#8 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 16 October 2013 - 11:50 AM
I think you may be right it does seem like a 5-5-5-5 so its not throwing a code?
#9 El Presidente
El Presidente
    Subaru Fanatic!
  • 609 posts
  • Northgate/Seattle, WA
Posted 16 October 2013 - 05:04 PM
Yeah, 34 or 35 is a EGR soleniod/valve(cant remember exactly) on 49 state cars for your year, continuous 5's is a designation code, so nothings wrong.
Is your CEL light on?
Josh
Edited by El Presidente, 16 October 2013 - 05:05 PM.
#10 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 16 October 2013 - 05:51 PM
no
#11 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 445 posts
  • Akron, OH
Posted 16 October 2013 - 06:44 PM
Yeah. I code 55 is 5 long pulses with 5 quick ones in succession. 5 quick pulses, continuously is "5" meaning Federal emmission, MT. No troubles.
#12 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 17 October 2013 - 08:00 AM
cool now I need to find out if this exhaust leak is causing major loss of low rpm power!
