front coil spring swap
7 replies to this topic
#1 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 19 October 2013 - 09:24 AM
I have the rear strut/spring swap done, over 10,000 miles on it.. Even after cutting some coils off the back the car still sits 3" higher in the back then front, and the front springs are to soft. I read of some suggestions on other springs that might work ford tempo, etc.... But other members have mentioned the ford tempo springs were to small. I dont want to waste $$ and buy springs that I cant use. Anyone have a front coil spring swap that works?
#2 El Presidente
El Presidente
    Subaru Fanatic!
  • 617 posts
  • Northgate/Seattle, WA
Posted 19 October 2013 - 05:50 PM
Tempo springs DO work, but dont lift it just on the springs, get or make a proper lift.
Josh
#3 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 21 October 2013 - 05:35 PM
why not? not intentionally but that is how the back is
#4 El Presidente
El Presidente
    Subaru Fanatic!
  • 617 posts
Posted 22 October 2013 - 02:44 AM
The back has different suspension than the front.
In the back, the wheel doesn't change chamber when it rotates up and down, its on a simple trailing arm. Lifting the front on springs only will change the geometry of the front suspension and you'll have horrible front chamber, not to mention you'll have about an inch or two of down travel which is hard on your struts. A proper lift will bring the top of the struts in towards the center of the car to offset the geometry change.
Josh
#5 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 22 October 2013 - 08:43 AM
good point! I would like to swap out for some stiffer ones still and keep it stock height. maybe get a lift kit but they seem pricey.
#6 Torry3393
Torry3393
    Newbie
  • Pip
  • 9 posts
  • priest river, Idaho
Posted 27 October 2013 - 09:33 PM
Guys are making lift kits on here cheap! Out of 2" square tubing...not sure who, but saw it on here somewhere.
#7 The Dude Abides
The Dude Abides
    WileE Coyote Super Genius
  • 2,998 posts
  • West Des Moines, IA
Posted 29 October 2013 - 09:51 PM
Id probably sell mine if you were interested.
#8 mike300z
mike300z
    New User
  • PipPipPip
  • 46 posts
  • Michigan
Posted 30 October 2013 - 07:35 AM
whats the price?
