Any other year fit 97 legacy L headlight w/ turn signal built in?
8 replies to this topic
#1 pixie
pixie
    Member
  • PipPip
  • 12 posts
  • ojai, CA
Posted 20 October 2013 - 05:42 PM
I have a 97 legacy L and can't find a headlight assembly with the built-in turn signal like the original, without special ordering a new one at too high a cost. Lots of places have the one that doesn't have the built-in turn signal but none have the one-piecer.
Does anyone know if the separate headlight and turn signal would fit and work instead, or if any other year or model's headlight assembly could fit and work?
Many thanks!!
#2 lmdew
lmdew
    _______
  • 3,727 posts
  • Colorado Springs
Posted 20 October 2013 - 06:16 PM
www.car-part.com
Lots of them in the yards in Colorado.
#3 pixie
pixie
    Member
  • PipPip
  • 12 posts
  • ojai, CA
Posted 20 October 2013 - 06:18 PM
I'm in Quebec, Canada... So hoping someone might know of a possible substitution. Thanks!
#4 bluedotsnow
bluedotsnow
    USMB is life!
  • 341 posts
  • Kirkwood, CA
Posted 20 October 2013 - 06:50 PM
YES one piece and two piece should be swappable, I was having a conversation with my roomie/mechanic about that he said that its just the housing that differs. wire sockets and mount points are the same so you can swap them around.
my goal is to fit up impreza head lights from around 98-99 and use the turn signal from the two piece. I like glass headlights!  mmmm fabrication!
#5 pixie
pixie
    Member
  • PipPip
  • 12 posts
  • ojai, CA
Posted 20 October 2013 - 07:08 PM
Sweet!
I'll head back to the yard tomorrow, and let you know how it turns out. Good luck with your project.
#6 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 20 October 2013 - 07:54 PM
Yes, the do fit. The 2 piece i believe was 1995 and may be 96
#7 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,936 posts
  • Charlottesburg, VA
Posted 20 October 2013 - 09:27 PM
95 and 96 had the one piece headlight housing with the signal housing built in. Some 97s had them as well, but anywhere you look for a 97 headlight housing they will give you listings for nothing but the two piece style.
Search for 95 or 96 Legacy (trim level doesn't matter) and you will get listings for the one piece.
Junkyards are good for low prices, but you may need to clean the lens because they all fade and yellow with age.
#8 pixie
pixie
    Member
  • PipPip
  • 12 posts
  • ojai, CA
Posted 21 October 2013 - 05:37 AM
Thanks guys! I'll let you know what works.
#9 pixie
pixie
    Member
  • PipPip
  • 12 posts
  • ojai, CA
Posted 11 November 2013 - 10:45 AM
Thanks for the advice! Good thing for this forum - every parts store I contacted said the two separate parts wouldn't fit... but as you all said,  they did! Used parts from a 1998 Legacy Outback. Had to cut the wires and use the connectors from my vehicle, but other than that: simple!
