Compromise snow tire size OBW & Legacy
8 replies to this topic
#1 hankosolder2
hankosolder2
    Subaru Nut
  • 709 posts
  • Chicago
Posted 29 October 2013 - 06:41 PM
I've got a '98 Legacy 4EAT and a '98 OBW 5MT. Is there a snow / tire rim combo which can fit both cars? The OBW has the larger brakes, so I don't think a standard Legacy rim/tire will clear. My concern is that both cars are high mileage and if one dies, I'd still like to be able to use the tires/rims on the other car for this winter.
TIA,
Nathan
#2 Rooster2
Rooster2
    Subaru Master
  • 4,706 posts
  • Indianapolis
Posted 29 October 2013 - 07:49 PM
Do both vehicles have 15" wheels??  I have a 98 OBW, so I know it has 15 inchers. Wondering if the Legacy may have 14" wheels??
#3 987687
987687
    Rally Suby!
  • 4,253 posts
  • Northern Maine
Posted 29 October 2013 - 08:36 PM
Unless the brakes have been swapped from something way newer, 15" rims will clear anything from the 90's.
#4 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,971 posts
  • Charlottesburg, VA
Posted 29 October 2013 - 10:51 PM
I've read that a 205/60/15 will clear the spring perches on a Legacy L or GT, but it may depend on tread design.
A 195/60/15 is the stock size for an L or GT equipped with 15" wheels. That size is quite a bit smaller than the stock outback tire, so running that size on the outback will cause the speedometer to read fast by about 5-7 mph at 60.
#5 hankosolder2
hankosolder2
    Subaru Nut
  • 709 posts
  • Chicago
Posted 30 October 2013 - 09:40 AM
The Legacy L has 14" wheels, with the stock 185/70/14.
#6 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 30 October 2013 - 10:17 AM
i had 195/60 15's which are about the same diameter as a 185-70 14.
These wheels cover a 2 pot caliper.
i have 205/60 15 with xt6 struts, real close to the spring perch, but a 205/70 is too large.
I vote on 195/60 15's in place of the 185/70 14
#7 Rooster2
Rooster2
    Subaru Master
  • 4,706 posts
  • Indianapolis
Posted 30 October 2013 - 10:28 AM
So you have 14" wheels on the Legacy L, and 15" wheels on the Outback.
I too vote for 195/60/15 size tires, but that means buying 15" wheels for the Legacy L
#8 Fairtax4me
Fairtax4me
    Sooberoo
  • 12,971 posts
Posted 30 October 2013 - 10:52 AM
Right, but they had an option for 15" wheels.
If an L has 15" optional wheels it will have 195/60/15 tires.
No new wheels needed. Mount the tires on the 15" outback wheels and you can put those on either the L or the Outback.
#9 hankosolder2
hankosolder2
    Subaru Nut
  • 709 posts
  • Chicago
Posted 30 October 2013 - 05:35 PM
Well, as luck would have it, I have a set of four like new snow tires size 195/60/15 from my Accord (it burned a valve and is going to be donated.) So, I will need a set of 15" rims which will fit the Subies (the Honda rims are 4-lug)  and I'll be golden. (I don't like seasonally swapping tires on to rims... too much hassle.) Thanks to all who helped.
