Cincy Posted October 31, 2013 Share Posted October 31, 2013 Just picked up 83 GL, 108K miles. In great shape. Everything works great, runs good, with exception of the sputtering /stalling when starting on gas from a stop, or when at speed and stepping on, it bogs down for a second, then back on again. Its a drop in power for a second then it kicks in. Does it at stops, and when cruising. I checked for vacuum leak using propane. Did not find any. Also disconnected EGR, no change. Put new fuel filter in, still there. Looking for help or others with similar issue and what was the fix? Quote Link to comment Share on other sites More sharing options...
Dakotademon7 Posted November 1, 2013 Share Posted November 1, 2013 I take it that it has a carb. It could be a bad accelerator pump in the carb. Quote Link to comment Share on other sites More sharing options...
Cincy Posted November 1, 2013 Author Share Posted November 1, 2013 Yes, it has the Carter Weber carb. I've seen that comment on other posts....I'll look into that. Is that accessible outside the carb or an internal component? I'm learning quickly. Thanks Quote Link to comment Share on other sites More sharing options...
BoxerRebellion Posted November 1, 2013 Share Posted November 1, 2013 Plugs and plug wires. Air filter. Never rule out the simple. Also, if it has the low of mileage, chances are it sat for some time. It would hurt nothing to rebuild the carb. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted November 1, 2013 Share Posted November 1, 2013 I have had a carter weber 1 bbl in an 83 FWD 5spd with high altitude kit. I found that the base would get loose. You remove the carb, and on the underside of the base plate there are screws into the carb that come loose. i had 'floppy carb' and would have high idles and backfires. Check this as a possibility; use loc tite Quote Link to comment Share on other sites More sharing options...
maozebong Posted November 1, 2013 Share Posted November 1, 2013 its most likely in the carb, depending on what the plugs look like, its probably some gunk in the air bleeds. Quote Link to comment Share on other sites More sharing options...
aba4430 Posted November 3, 2013 Share Posted November 3, 2013 Try replacing the fuel filters initially. Quote Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted November 3, 2013 Share Posted November 3, 2013 Also it worth to check the condition of the PCV Valve, lots of stalling and bogging problems I've solved on EA Engined Subarus, were related to Stuck open PCV valves. Kind Regards. Quote Link to comment Share on other sites More sharing options...
Cincy Posted November 4, 2013 Author Share Posted November 4, 2013 Thank you for the suggestions above....will give it a go this week! Much appreciated Quote Link to comment Share on other sites More sharing options...
