Junk Yard Interchangeable Tranny for my 99 Legacy? 2.2L, 5mt
I have a 1999 Legacy wagon with a 5 speed manual, 2.2l.
somehow the center differential got toasted and I think it will be
cheaper to drop in a new (used) tranny. From what I've read I can use
most any 5mt as long as the final drive is the same.
I have a TY754VAAAA, FINAL DRIVE IS A 3.900.
Will all of these tranny's bolt up to my 2.2L (phaze two, if that matters)?
I'd also be interested in advice on parts to replace while the tranny is out. A clutch kit of course, but any seals, or ...?
All transmissions in the list below have these four specs.
TR = 1.000
FD = 3.900
Center Dif = Viscous (4kgf)
Rear = Open
Model/Engine/Year Tranny # 1st 2nd 3rd 4th 5th rev
Impreza AWD 95 TY752VT3AA 3.545 2.111 1.448 1.088 0.825 3.416
Impreza EJ18E AWD 96 TY752VT4AA 3.545 2.111 1.448 1.088 0.825 3.416
Impreza EJ22E AWD 96 TY752VABBA 3.545 1.947 1.366 0.972 0.780 3.330
Impreza EJ18E AWD 97 TY752VT5AA 3.545 2.111 1.448 1.088 0.825 3.416
Impreza EJ22 AWD 97-98 TY752VA5AA 3.545 1.947 1.366 0.972 0.780 3.330
Impreza EJ22 99-00 TY754VA1AA 3.545 1.947 1.366 0.972 0.780 3.330
Impreza TS 02-03 TY754VC2AA 3.545 2.062 1.448 1.088 0.780 3.330
Impreza Outback 02-03 TY754VC2BA 3.545 2.062 1.448 1.088 0.780 3.330
Impreza TS 04 TY754VC4AA 3.545 2.111 1.448 1.088 0.780 3.330
Impreza Outback 04 TY754VC4BA 3.545 2.111 1.448 1.088 0.780 3.330
Legacy 94 TY752VAABA 3.545 2.111 1.448 1.088 0.780 3.416
Legacy 95-96 TY752VABAA 3.545 2.111 1.448 1.088 0.780 3.416
Legacy 97-98 TY752VACAA 3.545 2.111 1.448 1.088 0.780 3.416
Legacy 99 TY754VAAAA 3.545 2.111 1.448 1.088 0.780 3.330
Legacy L & Brighton 00 TY754VCAAA 3.454 2.062 1.448 1.088 0.780 3.330
Legacy L & Brighton 01-02 TY754VCBAA 3.454 2.062 1.448 1.088 0.780 3.330
Legacy Outback 01-02 TY754VCBCA 3.454 2.062 1.448 1.088 0.780 3.330
I hope this list helps others with Tranny issues. Took me a while to type up.
Unless, of course, you also swap the rear diff from the same car. Direct bolt in will have to have the 3.9 ratio.
If you found an Outback or Forester donor car, you could put both the transmission and the rear diff in there and you'd have a 4.44 ratio. The ratios just have to match. generally speaking the extra part will cost more $$$ but you never know what you may find. Helps to have options.
Well after calling ten auto wrecking yards in Seattle. They all tell me that my Transmission is a one year only and can only be swapped for an identical unit.
If this is true that's a hugh pain.
Of course they just looked it up on their computer and told me what the screen said.
true or not?
true or not?
Listings are just wrong on many Subaru's. Not just junkyard parts, but aftermarkets as well.. 1999 because it was a transitional year has tons of " one year only " parts which really cover 1999-2003 in most cases. Things like the transmission part numbers changed for 2000.. It's not like my 1995 Chevy truck which is truly a one year only because it has the 'new' interior with the old TBI fuel injection and OBD-1, so things like the gauge cluster is different tho it looks just like the 1996-1998
  • 2 months later...
I need to look for a transmission for my 97 Impreza Outback,  I have yet to find a source to tell me what the final drive ratio is in my car.  If it is 3.900 as in the OP can I look for a trans out of any of the cars listed?  I don't want to bother calling any of the wreckers till I know exactly what trannys will work.
the 97 impreza outback with the ej22 engine and manual trans has a 3.9 final drive ratio.
all cars 95 - 99 with the ej22 engine and manual trans have a 3.9 ratio.
(except the 96 outback manual trans, it has the ej22 and the 4.1 ratio manual trans, i think.)
you can use the manual trans from any ej22 car 95 - 99 except the 96 outback 5 speed.
search www.car-part.com , sort by distance.
you will have to search each model and year separately.
Thanks,  one more question.... is there a tag on the tranny that will tell me it is the correct match as I plan to get a tranny from a wrecker and I will not actually know for sure where they got it.  I have in the past been lead down the wrong path with parts from the wreckers.......
there will be an ID number on the trans bell housing,
but there is no way easy way to decipher the year or the ratio.
search car-part.com , some of those listing MAY show the ID#.
or go to opposedforces.com/parts,
look up any model , year, trans, and it will list the trans ID#.
but this usually isn't necessary,
the salvage yards are usually pretty good,
they know where their parts came from, model, year, engine, miles.
one tip, if you tell them you are looking for a 97 trans, they will not sell you one from a 96 or a 95.
they do not know that those will fit
and they do not want the headache of you trying to return it because it is the wrong one.
so locate the trans you want o their website, and then call looking for that trans.
Edited by johnceggleston
Thank you for the info, will start the search......
