Phantom PCV valve...
4 replies to this topic
#1 Ogrekhan
Ogrekhan
    USMB Regular
  • PipPipPip
  • 34 posts
  • Sioux City
Posted 10 November 2013 - 03:13 PM
Hey all,
First off my subie is an 83 4wd wagon with california emissions 2 barrel hitachi car. My air filter was getting fouled with oil so I decided to order a new PCV valve in order to fix the problem. I went out to replace said valve today only to find it doesn't exist as far as I can tell on my car.  The hoses from the valve covers to the air breather are both straight lines with no T's and from the many pic's and descriptions I've found in my searching the pcv is not in it's proper location nor is there any plugged opening where it might have been removed/deleted. The previous owner left me with a nightmare of vacuum leaks and taped wires that I have sorted out over time , but I can't even see where he could have modded or removed it. Anyone have any ideas/pics/help/new swear words I could use ?
Thanks Jeremy.S
#2 81EA81
81EA81
    Eat, Live, Breath Subaru
  • 387 posts
  • Spokane,WA
Posted 10 November 2013 - 04:06 PM
Sounds like you have found a fun car to work on. Your engine should be an EA81, which would be original to your 83 wagon.
I would say the easiest way to give you a general direction with no pics would be to find your oil cap.
First remove the spare tire if it is present.Follow the oil filler neck down to where it bolts to the engine block. In that general area there should be an EGR valve to your left(looking down at the engine from front). and the PCV valve to your right.
it will thread into the backside of the intake manifold. there should be a hose that leads upward to a tee, this should connect your drivers side valve cover and pcv to the air cleaner. there is also a little filter inside the air cleaner housing too.
I hope that gives you a basic idea. I will do my best to find a pic.
#3 Ogrekhan
Ogrekhan
    USMB Regular
  • PipPipPip
  • 34 posts
  • Sioux City
Posted 10 November 2013 - 05:45 PM
Hey,
Thank you very much for the response.  I followed your directions and the EGR is there but in the place where you indicated the PCV should be there is a threaded plug in the manifold. No T off the line on the drivers side from valve cover to the air breather either its just a straight line from cover to cleaner just like the passenger side. My brother is trying to get a few pics for me before it gets dark , and I'll see about getting them posted here so you can see what I mean. The previous owner seems to have disabled the EGR and I'm starting to suspect he removed the PCV and replaced it with that plug :angry:
Jeremy.S
#4 Ogrekhan
Ogrekhan
    USMB Regular
  • PipPipPip
  • 34 posts
  • Sioux City
Posted 10 November 2013 - 06:21 PM
Can't seem to post the photos up here from photobucket http://i641.photobuc...2c42293cef7.jpg  http://i641.photobuc...4f7fadc5854.jpg  Hope these links work. There is an arrow to the plug in question where I think the PCV may have been removed.
Jeremy.S
#5 BratRod
BratRod
    USMB is life!
  • 580 posts
  • Dallas, Texas
Posted 10 November 2013 - 09:22 PM
Yep that's it. I cant find the photo I had uploaded, but here is one.
http://www.ultimates...5399-pcv-valve/
