92_rugby_subie Posted November 12, 2013 Share Posted November 12, 2013 (edited) So am I missing anything? -Heads- resurfaced, valve grind and new valve stem seals. Oil Pump gasket (mickey mouse) -- 15066AA000 from Subaru Water pump from Aisin -- WPF-003 from Aisin WP by pass -- 807615041 from Subaru OEM Oil pump o-ring from Subaru OEM Timing belt kit -eBay Cam Case O-Rings (2) -- 13089AA010 from Subaru OEM Front main seal from timing belt kit Rear main seal (one I have is orange, the one on the motor is black...) Cam seals -- 806738040 from Subaru OEM Oil pan gasket -- 11121AA001 from Subaru OEM (and RTV) Valve cover grommets -- 13271AA051 from Subaru (expensive, I only needed 1 to complete my set of them since I gave one to a friend of mine) Valve cover gasket kit -- X1321-AA999 Graphite OEM head gaskets -- 899235 Intake gaskets (part number soon, gonna get OEM like suggested) Exhaust gaskets Upper rad hose -- 45161GA490 from Subaru OEM Lower rad hose -- 45161GA500 from Subaru OEM New clutch will be ordered soon. Exedy 15008 Wish I knew of a good radiator shop that was open on weekends as I want my radiator worked on, and checked since I know the oil and coolant have been mixing... And I wanna make a weekend project out of this... Should have the engine assembled within the month Edit: Some part numbers added, will keep adding as I get more parts... Edited November 13, 2013 by 92_rugby_subie 2 Quote Link to comment Share on other sites More sharing options...
Subruise Posted November 12, 2013 Share Posted November 12, 2013 i didnt see cam case o rings from the dealer on your list. they go between the cam tower and the head. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 12, 2013 Author Share Posted November 12, 2013 I will order those I also have a tube of anaerobic sealant for the WP and OP too Quote Link to comment Share on other sites More sharing options...
Dee2 Posted November 12, 2013 Share Posted November 12, 2013 Excellent listing. Hope this gets finalized for all to use. Quote Link to comment Share on other sites More sharing options...
jono Posted November 12, 2013 Share Posted November 12, 2013 not only cam seals that run on the shaft, there is the special larg blue o ring seals between cam seal carrier and cam tower Quote Link to comment Share on other sites More sharing options...
markjw Posted November 12, 2013 Share Posted November 12, 2013 Make certain the intake gaskets are OEM only. Anything else will fail prematurely. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 12, 2013 Author Share Posted November 12, 2013 Okay, so I just ordered the little o-rings, he asked if I needed big ones or little ones, I said they were decently small last I checked, so Im assuming those are the cam carrier ones... Ill have this list RE-Done with OEM part numbers on what I got from the dealership and try to keep it as clean as possible. Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 16, 2013 Author Share Posted November 16, 2013 I updated the post with the part numbers on what I currently have. Radiator will be pulled and sent to Macs Radiator for repaint, leak test and complete flush they are one of the few open on a weekend, so I can pull the radiator on a friday and get it back monday and back in the car Quote Link to comment Share on other sites More sharing options...
rain_man_rich Posted November 17, 2013 Share Posted November 17, 2013 Thanks for making the list Quote Link to comment Share on other sites More sharing options...
rain_man_rich Posted November 17, 2013 Share Posted November 17, 2013 Know what would be cool? If you put the prices you paid by each one so we'd have an idea of the cost. Quote Link to comment Share on other sites More sharing options...
Luvn737s Posted November 17, 2013 Share Posted November 17, 2013 How about new thermostat and gasket? Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 17, 2013 Author Share Posted November 17, 2013 That is on order as well. I will have prices up as soon as I'm on a computer Quote Link to comment Share on other sites More sharing options...
mandalore4411 Posted November 18, 2013 Share Posted November 18, 2013 i recommend ebay bro. look up ea82 gasket set Quote Link to comment Share on other sites More sharing options...
Luvn737s Posted November 18, 2013 Share Posted November 18, 2013 Make certain the intake gaskets are OEM only. Anything else will fail prematurely. The dealer sold me ones that have 2 holes each. How do I make sure they get the right ones? Does anyone have a part number for the correct gaskets, or does the Fel Pro set work OK? Quote Link to comment Share on other sites More sharing options...
92_rugby_subie Posted November 18, 2013 Author Share Posted November 18, 2013 Ill get a part number up, probably today as I plan to go in and check on my order at my dealership Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted November 18, 2013 Share Posted November 18, 2013 Mandalore, the reason he is putting this list together is that the OEM items are much higher quality than those "eBay specials". Would you want to go through the hassle of rebuilding the engine, only to have a cheap piece of spoob chinese gasket fail about 1000 miles later? Quote Link to comment Share on other sites More sharing options...
1988subiman Posted November 20, 2013 Share Posted November 20, 2013 So am I missing anything? -Heads- resurfaced, valve grind and new valve stem seals. Oil Pump gasket (mickey mouse) -- 15066AA000 from Subaru Water pump from Aisin -- WPF-003 from Aisin WP by pass -- 807615041 from Subaru OEM Oil pump o-ring from Subaru OEM Timing belt kit -eBay Cam Case O-Rings (2) -- 13089AA010 from Subaru OEM Front main seal from timing belt kit Rear main seal (one I have is orange, the one on the motor is black...) Cam seals -- 806738040 from Subaru OEM Oil pan gasket -- 11121AA001 from Subaru OEM (and RTV) Valve cover grommets -- 13271AA051 from Subaru (expensive, I only needed 1 to complete my set of them since I gave one to a friend of mine) Valve cover gasket kit -- X1321-AA999 Graphite OEM head gaskets -- 899235 Intake gaskets (part number soon, gonna get OEM like suggested) Exhaust gaskets Upper rad hose -- 45161GA490 from Subaru OEM Lower rad hose -- 45161GA500 from Subaru OEM New clutch will be ordered soon. Exedy 15008 Wish I knew of a good radiator shop that was open on weekends as I want my radiator worked on, and checked since I know the oil and coolant have been mixing... And I wanna make a weekend project out of this... Should have the engine assembled within the month Edit: Some part numbers added, will keep adding as I get more parts... How much did the oem headgaskets cost you ?? Quote Link to comment Share on other sites More sharing options...
