cam towers.
8 replies to this topic
#1 mandalore4411
mandalore4411
    New User
  • PipPipPip
  • 30 posts
  • Oregon
Posted 20 November 2013 - 01:01 AM
this may be really obvious but i just wanted to know for sure.
ea82 camtowers(everything in um) and put them onto an ea82T. they seem the same to me i just wondered if the lobes might be different or something, or the ditsy.
#2 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 20 November 2013 - 07:40 AM
IIRC, the turbo cam is different as is the distro (before/after 87? ) but the HLAs, valves, rockers, ect should be the same
#3 idosubaru
idosubaru
    Elite Master of the Subaru
  • 24,101 posts
  • East Coast
Posted 20 November 2013 - 09:00 AM
it is said the turbo cam is different, though i doubt you'd notice much difference if you needed to swap for a daily driver.
distributor is dependent more on years probably, would be best to keep matched to the vehicle as there are a few changes from 86, 87, 88.  pigtails can be swapped on some if that's the only difference.
#4 scoobiedubie
scoobiedubie
    USMB is life!
  • 701 posts
  • Aloha, Oregon
Posted 20 November 2013 - 02:49 PM
How is the turbo cam different?
#5 Mark Humble
Mark Humble
    USMB Regular
  • PipPipPip
  • 121 posts
  • Lewiston Ca.
Posted 20 November 2013 - 03:46 PM
No valve overlap on turbo cam.
Mark
#6 scoobiedubie
scoobiedubie
    USMB is life!
  • 701 posts
  • Aloha, Oregon
Posted 21 November 2013 - 12:25 AM
Mark
The valves are part of the cylinder head.  The cam is part of the camtower assembly.  The camtower cannot be different due to valve placement, because valves are not part of the camtower assembly.  I have interchanged my camtowers on my EA82T and camtowers off of a EA82, with no problems.
#7 Mark Humble
Mark Humble
    USMB Regular
  • PipPipPip
  • 121 posts
  • Lewiston Ca.
Posted 21 November 2013 - 01:27 AM
Valve overlap is a term used to describe the duration when both the intake and exhaust valves are open at the same time. On most turbo engines, the valves are not open at the same time because the pressure on the exhaust side is greater than the intake side, or the boost pressure. On a N/A engine, the valves will be open at the same time for a short duration. This will cause the out going exhaust gases to help draw in the fuel/air charge. The total duration of valve overlap is determined by many factors, and one of those cam designer's secrets. I hope this helps. I too think it may not make a lot of difference for a daily driver.
Mark
#8 NorthWet
NorthWet
    Eeyore Incarnate
  • 5,039 posts
  • Bremerton, WA
Posted 21 November 2013 - 02:36 AM
IIRC, the 85 and 86 turbo cam profile differed little, if any, from the non-turbo.  The 87-up had alterations in the timing, duration and overlap, with a slightly decreased overlap as compared to the non-turbos.  In essence, the later turbo cam was a milder grind.  There is a thread floating around that lists the various cams.  I think that post was by Gloyale, and relatively recently.
#9 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 21 November 2013 - 10:30 AM
As has been said, the cam is different, but the tower is not.
However, if youre going to drop a turbo cam on a non turbo motor, id suggest you do it for both sides. The valve timing is different IIRC..
