Cruise Control issue
cruise control
2 replies to this topic
#1 disciplejohn52
disciplejohn52
    New User
  • PipPip
  • 10 posts
  • Fenton
Posted 20 November 2013 - 06:34 AM
93 legacy 2.2 wagon
cruise control will engage and power the vehicle forward, but much lower than the set speed, and then only on flat or descending inclines. If I encounter a slight uphill, then it slows.
Example: I set it at 45 MPH on a slight downhill, and it maintained it, but when I encountered an uphill portion of the road it slowed to 30 and stayed at thirty until the next downhill. At higher speeds (65 MPH) it won't maintain at all but will fall back to 55-60 even on flats or slight downhills.
Thoughts?
On a slightly unrelated note, the speedometer cable has recently(past 2 weeks) become noisy. Is it possible to lube, or should I just replace? The cruise issue is a year old, so I wouldn't think there's a correlation between the two, but...
#2 heartless
heartless
    Do YOU Subaru?
  • 3,323 posts
  • North Central Wisconsin
Posted 20 November 2013 - 07:17 AM
the cruise issue sounds like it might be vacuum related - when was the last time you checked/replaced vacuum lines? old, hard, brittle vacuum lines wont hold as good a vacuum as new soft/supple ones will.
#3 Fairtax4me
Fairtax4me
    Sooberoo
  • 13,031 posts
  • Charlottesburg, VA
Posted 21 November 2013 - 12:30 AM
Sounds like its losing vacuum or the actuator servo isn't holding vacuum.
Did you install the cruise?
Does it use a vacuum pump or engine vacuum for the source?
Also tagged with one or more of these keywords: cruise control
