SubDrew207 Posted December 6, 2013 Share Posted December 6, 2013 (edited) Ok so this is probably been answered someplace unknown to me. I have a 1999 Subaru legacy outback SUS EJ25D with the 8 bolt bell housing hookup. I continue to run into people saying that car is type specific as far as engines go. what are my options? can I use a JDM 4 bolt EJ25D or EJ22 because I cant seem to find a 25 that's not high miles and very expensive 1300$ was the best I could find. I am interested in these 4 bolt JDM motors. will they work Plug and Play with my 99 SUS? Thanks all this is the JDM I would like to use Edited December 6, 2013 by SubDrew207 Quote Link to comment Share on other sites More sharing options...
matt167 Posted December 6, 2013 Share Posted December 6, 2013 (edited) Yes and no.. The 4 bolt JDM 2.2L will fit and work with the 8 bolt SUS transmission. The bellhousing patterns match and the engine would hook up and run with the EJ25D harness.. The JDM's do not have EGR so if you live in an inspection state where the CEL cannot be on then it will not pass without an EGR manifold and some trickery.. If you want a bolt and go reliable engine. A 1995-1996 EJ22 from an automatic Legacy would have the EGR and fit and run just like the JDM.. My '99 SUS has a '96 EJ22 in it. You need to install the flexplate from the EJ25 on the EJ22. It looks tight but it fits and works Edited December 6, 2013 by matt167 Quote Link to comment Share on other sites More sharing options...
SubDrew207 Posted December 6, 2013 Author Share Posted December 6, 2013 (edited) could I tap and die the egr port on a jdm engine and hook it up or does the engine not allow that?This is the engine link I have found some info on EGR installations to jdm motors. I want to be sure before I make a purchase that the 4 bolt engine will work with my tranny 8 bolts. http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=231090939179&fromMakeTrack=true&ssPageName=VIP:watchlink:top:en Or could I take my ej25d manifold from the sus and install it on the jdm ej25d and tap and die the egr port? Thanks Edited December 7, 2013 by SubDrew207 Quote Link to comment Share on other sites More sharing options...
matt167 Posted December 7, 2013 Share Posted December 7, 2013 (edited) I would not install an EJ25D, JDM or otherwise. EJ22E only.. You could drill and tap the cylinder head for the EGR but you would still need an EGR intake manifold and wiring harness with the EGR plug.. With an EGR intake manifold you could also tie the EGR valve into one of the hoses on the back airbox and that would keep the CEL off The 4 bolt engine will fit the 8 bolt trans. I have done it and it's a very common swap Edited December 7, 2013 by matt167 Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 7, 2013 Share Posted December 7, 2013 (edited) I'd also go with an EJ22 swap. Amazing motor and easy to find since they're zero demand (because they don't eat rod bearings and headgaskets like EJ25's) . I want to be sure before I make a purchase that the 4 bolt engine will work with my tranny 8 bolts. Or could I take my ej25d manifold from the sus and install it on the jdm ej25d and tap and die the egr port? Thanks Keep in mind JDM's are nothing magical, they're the same gasket and engine prone to headgaskets blowing too. 4 bolt 8 bolt doesn't matter, bolts right up either way. bolt US intake manifold to JDM engine. there's a thread on how to bypass the EGR code, very simple and not get a code. no drilling/tapping/installing EGR required. find that thread. i have a 120k EJ25, PM or email me if interested. Edited December 7, 2013 by grossgary Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted December 7, 2013 Share Posted December 7, 2013 Here's the thread about egr http://www.ultimatesubaru.org/forum/topic/137829-using-a-non-egr-engine-in-subaru-with-egr-exhaust-gas-recirculation-valve/?do=findComment&comment=1160910 Quote Link to comment Share on other sites More sharing options...
SubDrew207 Posted December 9, 2013 Author Share Posted December 9, 2013 Update: ok so I found a 98 Subaru legacy outback ej25d with the heads done and timing belt water pump ect. will this bolt up to my 99 sus tranny. I think from the research i've don't that it should no problem including the wiring harness? I am paying 600$ and the guys gonna pull it from his car for me. In advance thanks all you Subaru techy Quote Link to comment Share on other sites More sharing options...
idosubaru Posted December 9, 2013 Share Posted December 9, 2013 Yes, it's plug and play. ALL 1996 - 1999 EJ25 DOHC engines are plug and play. bolt in, plug in, done. 99 SUS is EJ25 DOHC and all 1998 and earlier EJ25's are EJ25 DOHC engines too. Quote Link to comment Share on other sites More sharing options...
