reedbj40 Posted December 10, 2013 Share Posted December 10, 2013 Hey guys, New to USMB here. Awesome to know that these things exist for those who enjoy these rigs. I have had an issue I have been chasing around in my '90 loyale wagon. It stalled out when driving one morning and since, has only been able to warm up on high idle, then loads up w/ fuel & stalls. I have changed the injector (SPFI), and cleaned out the MAF, but to no avail. Any Ideas? Quote Link to comment Share on other sites More sharing options...
NorthWet Posted December 10, 2013 Share Posted December 10, 2013 Have you checked the Coolant Temperature Sensor (CTS)? The connections on them to corrode. Quote Link to comment Share on other sites More sharing options...
reedbj40 Posted December 10, 2013 Author Share Posted December 10, 2013 I hadn't checked the CTS, but will. I ruled it out since it seems to be kicking down from high idle just as it floods and stalls. I will look it over though, Thanks. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted December 10, 2013 Share Posted December 10, 2013 How are you determining it's loading up with fuel? Have you confirmed that you still have spark after it dies? Sometimes coil/transitor fail after warmed up. Quote Link to comment Share on other sites More sharing options...
reedbj40 Posted December 10, 2013 Author Share Posted December 10, 2013 I have checked spark at the plugs after it has warmed up, and still has plenty. I have not actually measured it though. I may have to see how much juice is making it there after it has warmed a bit. The reason for assuming the fuel issue was the substantial amount of fuel being cycled through when trying to start after a stall, but that would be quite a bit if there were not spark to consume it. I'll look into the coil and see also. Thank you guys. Quote Link to comment Share on other sites More sharing options...
reedbj40 Posted December 15, 2013 Author Share Posted December 15, 2013 Ok. I replaced the ignition coil, the old one looked as though it may have been factory. No dice. Still starts right up, idles for a while, then chokes out. It doesn't seem to warm up to low idle. I checked connections to coolant temp sensor, they look fine. I have no check engine light on when idling, but after it died out, I plugged in the green connector against firewall on drivers side and checked ecu light. Turned key to on. Consistently 7 quick flashes. I am at a loss here. If anyone has dealt with something like this, please help. Thanks. Quote Link to comment Share on other sites More sharing options...
MilesFox Posted December 15, 2013 Share Posted December 15, 2013 The 7 flashes is an identity code (i.e, spfi, at, usa, 49 state) Based on your symptoms, i would guess either the MAF is fouled, dirty, bad, or has a poor connnection, or any of the intake piping or hoses going to it are loise or have a leak. Maybe the idle air control valve is not opening. You will want to test the resistance to the coolant temp sensor to check it. See if the car behaves differently withthe CTS unplugged. See what will happen if you unplug the MAF and start the car. any old timer knowledge with old chevys and carburetors need not apply with the subaru, as it will lead you to the wrong conclusions. Quote Link to comment Share on other sites More sharing options...
reedbj40 Posted December 16, 2013 Author Share Posted December 16, 2013 I checked over MAF and coolant temp sensor (resistance at sensors and voltage from connectors). Also tested resistance of IAC. All are within tolerances as specified by Chilton manual. I had thought that MAF may have been it due to a clogged PCV valve sending oil into the intake, but that has been changed and the intake boot & MAF sensor have been cleaned w/ MAF cleaner. Is it possible that oil has made it into the TBI and burning, causing excess carbon on catylitic converter, maybe clogging it? Not sure though, please advise. Quote Link to comment Share on other sites More sharing options...
reedbj40 Posted December 16, 2013 Author Share Posted December 16, 2013 P.S. No difference w/ MAF sensor unplugged. Still stalls out. Quote Link to comment Share on other sites More sharing options...
naru Posted December 16, 2013 Share Posted December 16, 2013 Sounds more like your garden variety unmetered air/vacuum leak from this great distance, Leak becomes more significant as idle air supply decreases. Check the intake tract for cracks etc, Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted December 16, 2013 Share Posted December 16, 2013 I'll second checking the intake boot for leaks. That rubber boot likes to crack with age, especially where the corrugations are. Mine is wrapped in a layer of electrical tape at both ends where the corrugations are for just that reason, they were looking pretty crackly so I 'sealed' them. Quote Link to comment Share on other sites More sharing options...
