millhouse Posted December 11, 2013 Share Posted December 11, 2013 Hi All, This is Andrew here again. I am still trying to tackle this bogging out issue. My Brat runs really well when its not warmed up, but once it is warm it losses power when moving from a stopped position. I have completely rebuilt the carb and at this point I am pretty much done dealing with it. Its the stock carb and I am thinking its time to replace it with one of those webber carbs. Does anyone have a link to the carb that will work with my 1985 Brat 1.8L? As always, thanks in advance for your support and help. Cheers, Andrew Quote Link to comment Share on other sites More sharing options...
BratRod Posted December 11, 2013 Share Posted December 11, 2013 http://m.ebay.com/itm?itemId=281221126808 This is through the admin of the site (ShawnW). He owns a Subaru specialty shop, so rest assured that this is the correct kit. There are multiple writeups on how to do this swap. It is very simple with some patience. Quote Link to comment Share on other sites More sharing options...
millhouse Posted December 11, 2013 Author Share Posted December 11, 2013 http://m.ebay.com/itm?itemId=281221126808 This is through the admin of the site (ShawnW). He owns a Subaru specialty shop, so rest assured that this is the correct kit. There are multiple writeups on how to do this swap. It is very simple with some patience. Looks like that one ended. Also, do you have a link to how to do this swap? Thanks BratRod! Quote Link to comment Share on other sites More sharing options...
BratRod Posted December 12, 2013 Share Posted December 12, 2013 (edited) My apologies, I did that from my phone and hadn't noticed. You can still message him through Ebay, or PM on here. Im sure you could call his shop, too (RetroRoo). http://www.ultimatesubaru.org/forum/topic/71510-ideas-on-swaping-a-weber-carb-on-ea82%C2%B4s/ I would save those pics, as Jezek reaches his bandwidth limit on Photobucket pretty quick. Or take screenshots. Note: That write-up is for an EA82 engine. It is similar enough to you EA81 to get you through the swap, though. There are other, more complicated, options rather than the Weber. There is the Fuel injection conversion, (http://www.leoneturbo.com/docs/EA81_SPI_guide.pdf) and then the almighty EJ conversion. The Weber is BY FAR the easiest. Edit: http://www.indysworld.com/80s/general/USRM/mick-usrm/weber/weber.html There is another one. I can't find the one I'm looking for. It's on here somewhere. Hopefully another member will post it. That should give you an idea. Edited December 12, 2013 by BratRod Quote Link to comment Share on other sites More sharing options...
bratman2 Posted December 12, 2013 Share Posted December 12, 2013 Andrew, I went through a terrible drivability issue with my 87 Brat many years ago. Like you I felt it was the carburetor and replaced mine with a Webber! It fixed the problem even though I don't think the carb was the problem. I might get the name wrong but there are exhaust recirculating valves (I think that is what they are) on the bottom of your exhaust manifolds. They can hang up and cause all kinds of problems. Mine were capped for the Webber install and why I think that is what really fixed my Brat. My problems if memory serves me was similar to yours. When cold it seemed to do okay, as it got warm it would lose power to the point you would have to down shift to maintain speed. Sometime it would backfire when shifting also. Might want to try blocking those off first! A Webber will give a little better performance just the same but if your carburetor was properly rebuilt it would be a shame to can it!! Quote Link to comment Share on other sites More sharing options...
