'85 turbo wagon rough idle and dies....
1 reply to this topic
#1 Tubehead.ed
Tubehead.ed
    Newbie
  • Pip
  • 7 posts
  • PNW
Posted 15 December 2013 - 10:39 PM
 I have a 1985 GL wagon, automatic tranny, 70,000 original miles with a rebuild about 8,000 miles ago. It starts up immediatly cold or hot. When cold it will initallly have an idle of about 1600rpm, and settle down within a short period to a 900-1,000rpm. Driving it locally and on the highway it is fine,has nice smooth acceleration . Once it has warmed up and I come to a stop, it typically will idle  below 900. If i shut it off for a short period, restart it, the idle is around 500 and it begins a slow rough downward spirl until it dies. A mechanic looked at it and immediatly thought it was a valve,did a compression check and found the compression to range from 110 to 130 psi. The only  other symptom I noticed was the distinct smell of oil on hot metal after I  have driven it for 15+ minutes and shut the engine off. Suggestions as to what to look for? Thanks,Ed
#2 naru
naru
    1000+ Super USER!
  • 2,301 posts
  • under the bridge
Posted 16 December 2013 - 08:31 AM
Sounds like a plug fouls.Could be fuel or coolant.
Does a good REV or two improve matters?
I would start by inspecting the CTS connector for corrosion and the sender for resistance.
Next,check fuel pressure to see if it drops after shutdown because of a leaky injector.
See if you can identify a dead cylinder by pulling plug wires.
Pull plugs after a short period to inspect for fuel and coolant.
Make sure spark is as strong as w/cold.
Since the problem only begins after a hot soak,I`m guessing it is not the usual unmetered air/vacuum leak from the rubber intake tract
or rock hard PCV/vacuum hoses that the turbos suffer from.
Worth checking anyway.
Edited by naru, 16 December 2013 - 08:33 AM.
