2007 Subaru legacy 2.5i
I was on my way to pick up my lunch when My check engine light came on with the cruise light flashing. I borrowed a code from a friend at work, and was throwing a p0028. Just last night I noticed my oil was way low (its been a while since I put any in just got marred started a new job and relocated it slipped my mind oops) I put in 2 qt of 5w 30 as per the manual (i know not enough but wanted to hold it over oil at gas stations is a rip off)
I deleted the code, and restarted the car and the code is gone. Took it for a tiny loop around the parking lot (will try a longer ride on my next break) Idk if it's my imagination or what but it seems after deleting the code when starting the car the revs momentarily drop almost to a stall but then go to normal...it might just be because its cold.
Is it deff my solenoid? I haven't had a chance to check for a leak. Will look on my bake.
Suggestions?
Please help Obi Wan...you're my only hope...
