Rpms drop when brakes applied?
4 replies to this topic
#1 Subinoobi
    Advanced Member
  • PipPipPip
  • 58 posts
  • Kent WA
Posted 27 December 2013 - 02:11 AM
So I just got done doing a reseal on my motor, and now I'm having problems with my idle. If I apply the brakes, the first pump sinks to the floor, then it build pressure. And when I hit the brake my idle goes down and it almost dies. Now At first I though okay, maybe it's my brake booster, but my rpms drop when I turn on my defrost at full blast as well. I've checked every single vacuum line and ground I could find like 10 times, nothing seems out of place. i have a fresh battery and new cables as well, so my next thought is maybe the alternator. If it's not that, anyone have any experience with this and have some input? I have a 90 loyale spfi btw
#2 el_freddo
    Eat, Live, Breath Subaru
  • 768 posts
  • Lancefield, Vic, Aust.
Posted 27 December 2013 - 06:51 AM
The rev thing with the brakes applied points to the booster - make sure the one way valve in the line is working properly - it's under the metal clamp somewhere in the line, I can't remember where exactly.
The rev drop with the demist on could be a dodgy earth connection between the engine and the body - look into your earth strap on the engine and make sure it's securely fastened to the engine and the battery/body.
#3 Gloyale
    It's a sickness
  • 10,716 posts
  • Corvallis, OR PNW
Posted 27 December 2013 - 04:10 PM
Brake booster.
#4 86 Wonder Wedge
86 Wonder Wedge
    USMB Regular
  • 455 posts
  • Akron, OH
Posted 02 January 2014 - 09:10 PM
Make sure the vacuum line to the booster isn't kinked as well
#5 MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
Posted 02 January 2014 - 09:11 PM
Did you remove the brake booster line from the car side? there is a check valve in the line; make sure it is not installed backward. I take it this problem didn't occur before resealing the engine.
