Universal fuel pump for loyale
7 replies to this topic
#1 Carl B.
Carl B.
    USMB Regular
  • 129 posts
  • Colorado
Posted 28 December 2013 - 04:48 PM
Need a new fuel pump for 91 loyale spfi.  Replacements are so expensive I was wondering if someone new a universal pump that would work.  Or anyone know the specs of the stock one?
thanks
*edit:  found a cheap and readily available fuel pump. airtex e2000  stock replacement for older f-series and the Merkur coincidentally.
Edited by Carl B., 28 December 2013 - 07:58 PM.
#2 Gloyale
Gloyale
    It's a sickness
  • 10,840 posts
  • Corvallis, OR PNW
Posted 28 December 2013 - 04:54 PM
Universals with a High pressure (above 40) and at least 180 GPH will surfice.
Still gonna be spendy.
I run a walbro 255 in mine with an EJ22.
#3 MilesFox
MilesFox
    Catch this Fox!
  • 10,686 posts
  • Madison/Milwaukee, WI
ford truck dual tank rear external pump
#4 Carl B.
Carl B.
    USMB Regular
  • 129 posts
  • Colorado
Posted 28 December 2013 - 04:58 PM
I found specs for a factory replacement pump.
http://www.fuelpumpu...le-search.aspx#
That walbro 255 sounds like a little much; used one on a Merkur at 22psi of boost and it supplied enough fuel.
Thanks for the quick replies
Edited by Carl B., 28 December 2013 - 04:58 PM.
#5 Carl B.
Carl B.
    USMB Regular
  • 129 posts
  • Colorado
Posted 28 December 2013 - 07:08 PM
Used an Airtex e2000 fuel pump.  It was referenced when I was searching for the ford aux tank pump.  Seems to work just fine, fits in the stock location using a hose clamp, and only cost $65!
Edited by Carl B., 28 December 2013 - 07:08 PM.
#6 suprjohn
suprjohn
    Eat, Live, Breath Subaru
  • 260 posts
  • North Platte, NE
Posted 28 December 2013 - 11:42 PM
I got one that was listed for my '89 DL, SPFI from rock auto for $20 just because there weren't many left and I saw how much other pumps were going for. The one on mine still seems tho work fine, but I wanted one for just in case...
John
#7 Rust
Rust
  • 1,079 posts
  • The Sticks
Posted 30 December 2013 - 02:15 PM
http://www.rockauto....0505&cc=1121836
Been running one of these on one of my ea82 cars, 2 yrs and no problems.
#8 ford'ssubaru's
ford'ssubaru's
  • Gold Subscribers
  • 282 posts
  • SPOKANE
Posted 30 December 2013 - 03:52 PM
Went to Pull and Save and pulled three.  I have two on the shelf.....
