Armchair Bronco Posted December 31, 2013 Share Posted December 31, 2013 (edited) I just purchased a 2000 Impreza 2.2L Sedan for my 3 teenage kids to share. I'd like to install the OEM fog light kit on this car, but I have a few questions. * A user on another site said "the car should already be pre-wired for the fog light kit". Is this correct? I'm hoping that I only need to get a kit for part # H4510FA220: 1997 2001 Subaru Impreza Fog Light Lamps New Genuine | eBay * If the car isn't pre-wired, then what else would I need in addition to the kit? * I'm seeing kits for part # H4510FA220 ranging from $158 to $199. Are these the same kits? Some kits don't have photos, so I can't tell. * The installation instruction from the thread below only refer to 1998 and 1999 models; mine is a 2000 model. Any guesses about installation differences for the 2000 model? (http://www.rs25.com/forums/f105/t138379-my97-01l-oem-fog-light-kit-install-instructions.html) * Is this something I can install myself over a weekend? I have decades of experience building model airplanes from scratch, and I have also built and soldered many guitar pedals, but I've never done *any* automotive work. I do have all the tools I'd need. Here's a photo of the parts in the kit: And here's the front-end of my Subaru. It looks like my covers are for round fog lights, but the ones in the kit are more rectangular shaped. Edited December 31, 2013 by Armchair Bronco Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 31, 2013 Share Posted December 31, 2013 I'm not familiar with the Impreza fog light mounting. Legacy from that era was incredibly easy to install. It looks like the kit includes all of the brackets you should need. For wiring its pretty simple. The factory wiring kits are simple to install, but fairly expensive. If there's a junk yard nearby that lets you pull parts yourself that would be good to get a wire kit from. Cheaper, and you can see how its routed and where all the wires connect. Be sure to get the relay as well. Quote Link to comment Share on other sites More sharing options...
Armchair Bronco Posted December 31, 2013 Author Share Posted December 31, 2013 I'm not familiar with the Impreza fog light mounting. Legacy from that era was incredibly easy to install. It looks like the kit includes all of the brackets you should need. For wiring its pretty simple. The factory wiring kits are simple to install, but fairly expensive. If there's a junk yard nearby that lets you pull parts yourself that would be good to get a wire kit from. Cheaper, and you can see how its routed and where all the wires connect. Be sure to get the relay as well. If I had more time, or if there were a junkyard relatively close to me that might be an option. But the nearest big junkyard is a bit of a trek. It sounds like you're saying that if I get the kit, it will include everything I need, correct? I may pay more than sourcing the parts myself, but I'm seeing these kits for under $160 which doesn't seem like highway robbery. Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 31, 2013 Share Posted December 31, 2013 I took a closer look at that eBay kit and it actually comes with all of the wiring and the factory switch you need! No need to buy anything else if you get that kit! Good find! I think the relay is in the yellow box. The switch is the black rectangle covered up by the green T. I would expect a kit like that to come with some kind of instructions. Quote Link to comment Share on other sites More sharing options...
Armchair Bronco Posted December 31, 2013 Author Share Posted December 31, 2013 I took a closer look at that eBay kit and it actually comes with all of the wiring and the factory switch you need! No need to buy anything else if you get that kit! Good find! I think the relay is in the yellow box. The switch is the black rectangle covered up by the green T. I would expect a kit like that to come with some kind of instructions. The RS25.com link I provided in the OP has scans of a 4-page instruction sheet from an OEM fog light kit. I'm including them here for completeness in this thread. The one question I have is that these instructions only refer to 1998 and 1999 models, and the installation location for the switch is different for each model year. My car is a 2000 year model. I'm going to assume that I should follow the 1999 instructions unless I hear otherwise. Quote Link to comment Share on other sites More sharing options...
Armchair Bronco Posted December 31, 2013 Author Share Posted December 31, 2013 There *seem* to be a LOT of sites selling this kit, but the only one with a photo is in the OP above (eBay auction). Unfortunately, that one is also the most expensive at $199. Here's what I've found so far (from most to least expensive), searching for "H4510FA220". eBay - $199.95 - http://www.ebay.com/itm/200997879241?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 eBay - $187.15 - http://www.ebay.com/itm/200997879241?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649 eBay - $179.96 - http://www.ebay.com/itm/SUBARU-H4510FA220-GENUINE-OEM-FACTORY-ORIGINAL-FOG-LAMP-/161167848570?pt=Motors_Car_Truck_Parts_Accessories&hash=item25865a347a&vxp=mtr Subaru Parts Vendor - $159.96 - http://www.buysubarupartsnow.com/oem-part/subaru/impreza-parts/2000/base/2-2l-h4-gas/electrical/fog-lamps/fog-lamp/h4510fa220?search_str=H4510FA220 Subaru Parts Vendor - $159.96 - http://www.subarupartswebsite.com/OEMParts/subaru-153/H/H4510FA220.html Subaru Parts Vendor - $158.60 - http://www.subarugenuineparts.com/product_reviews_info.php?products_id=269&reviews_id=320 Subaru Parts Vendor - $158.56 - http://subaruonlineparts.com/oemparts/H4510FA220 Quote Link to comment Share on other sites More sharing options...
Fairtax4me Posted December 31, 2013 Share Posted December 31, 2013 If you order it from a Subaru dealer site you'll definitely get the right parts. Find an online dealer relatively close to you to save some on shipping. 1stsubaruparts.com has it for $155.96. Quote Link to comment Share on other sites More sharing options...
Armchair Bronco Posted December 31, 2013 Author Share Posted December 31, 2013 If you order it from a Subaru dealer site you'll definitely get the right parts. Find an online dealer relatively close to you to save some on shipping. 1stsubaruparts.com has it for $155.96. Thanks. These guys are also in Olympia, WA...about an hour south of me. (It might be faster to just drive there!) Anyway, I'll call around tomorrow. Some site ship for free, others have a shipping cost based on the final sales price. I'll need to compare apples and apples. Quote Link to comment Share on other sites More sharing options...
